[mapguide-users] Trusted Sites
Chris Tallman ctallman at innomap.com
Thu Dec 20 07:21:27 EST 2007
I see the same gap at the top of the map.  The gap is there when the
properties pane is turned off, and there is no gap when the properties
pane is on. I also see if you resize the map the gap goes away and
everything is fine.
So its got to be a bug some place in the AJAX Viewer. I think I remember
some posts about this gap a week ago or more.  Have to search the old
posts.
Chris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Gunter
Becker
Sent: Thursday, December 20, 2007 3:57 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Trusted Sites
Hi Chris,
I've made yesterday exactly the same experience like you but didn't
realise that the tooltip shows up when moving the mouse cursor north of
the object.
I thought I've done something wrong but now think it's a bug in AJAX
Viewer.
When you have a colored background (I mean for eyample a polygon layer
behind your symbol layer) you can see that there is a gap between the
toolbar and the map. If you resize your window the map gets refreshed
and that gap will disappear and the tooltip shows correct.
http://www.nabble.com/file/p14432821/Clipboard.jpg
So it has to be a JavaScript problem in the AJAX viewer when the viewer
is initialised I suppose.
Gunter
View this message in context:
http://www.nabble.com/Trusted-Sites-tp14401044s16610p14432821.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
