[mapguide-users] WMS Link question
BradM masonb at dfo-mpo.gc.ca
Thu Dec 20 10:29:24 EST 2007
Hi Tom, I have been trying to access this wms source for about a year now.
We are using MGE 2008.  Will we need to install the MGO beta 2.0 to get this
working? We tried installing the new beta 2.0 side by side with MGE 2008 but
we had problems and had to abort.
thanks
Tom Fukushima wrote:
> Ah, that is a ERMapper WMS server I think.  The ERMapper WMS server does
> not accept URL encoded WMS requests.
> So for example the following request will work:
> http://openmaps.gov.bc.ca/ecwp2/ecw_wms.dll?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=BC_BC_BARKBEETLE_XC1M_BCALB_2004&STYLES=&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SRS=EPSG:102190&BBOX=-443475.547681155,-47702.6055951556,2547804.45231885,2104297.39440484&WIDTH=556&HEIGHT=400
> But if we URL Encode some of the parts of the request, in this case, the
> SRS colon to %3a (look for EPSG%3a102190 in the following URL) then it
> fails:
> http://openmaps.gov.bc.ca/ecwp2/ecw_wms.dll?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=BC_BC_BARKBEETLE_XC1M_BCALB_2004&STYLES=&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SRS=EPSG%3a102190&BBOX=-443475.547681155,-47702.6055951556,2547804.45231885,2104297.39440484&WIDTH=556&HEIGHT=400
> A fix was applied to the WMS provider in the FDO project:
> http://trac.osgeo.org/fdo/changeset/3243
> http://trac.osgeo.org/fdo/ticket/110
> This fix is in FDO 3.3 and so will be part of the upcoming MGOS 2.0
> release.
> Tom
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of NJgeo
> Sent: Monday, November 05, 2007 4:12 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] WMS Link question
> MGE 2008 and Studio 2008
> hmm ... so I see the error message when I try to preview it in the wms
> configuration.
> then when I try to create a layer I cannot see anything in preview.  I
> created a map with specfic extents and still nothing  I have attached the
> layer settings to this post hopefully if you look you can shed some light
> on
> it...thanks again!
> N
> Andy Morsell wrote:
>> Which version of MapGuide and Studio are you using?  I just tried using
>> that
>> WMS service with MGOS 1.2 and Studio 2008 and the connection seemed fine.
>> I
>> was able to see all of the feature sources in a new layer dialog when it
>> enumerated for the feature class.
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> http://www.SpatialGIS.com
>> Sent: Monday, November 05, 2007 1:06 PM
>> Subject: [mapguide-users] WMS Link question
>> I am trying to connect to an wms service via MapGuide Studio and I am
>> getting the following error
>> the service is
>> http://openmaps.gov.bc.ca/images/base.xml
>> An exception occurred in FDO component. Element
>> 'TempSchema:BC_BC_BC_XC10M_BCALB_20070115' references class (BC) which
>> does
>> not belong to a feature schema
>> any help with this and how I can fix it would be awesome...thanks in
>> advance
>> N
>> View this message in context:
>> http://www.nabble.com/WMS-Link-question-tf4754434s16610.html#a13595664
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/file/p13597752/wmswoes.jpg
> http://www.nabble.com/WMS-Link-question-tf4754434s16610.html#a13597752
View this message in context: http://www.nabble.com/WMS-Link-question-tp13595664s16610p14438452.html
