[mapguide-users] search error: "Identity property type
notsupported yet (8)"
Michael L.
bjoern07-web at yahoo.de
Thu Dec 20 14:38:06 EST 2007
I will test the Unicode issue tomorrow. I already informed Autodesk about
this problem, but still got no reply. I'm under time pressure setting up a
working GIS so this forum is really helpful for me. After I posted this
error message I found on Jason Birch's homepage a sample query "MapGuide
Open Source / Enterprise GT - Test Application". This code sample is
fantastic. The query works without any problems in combination with Oracle
10g. So I’m able to search my data. Thanks a lot Jason for this code.
Michael
JasonBirch wrote:
> Hi Michael,
> When you're using MapGuide Enterprise, you're also using the proprietary
> Oracle provider, so others who are not using Enterprise can't help.
> Have you tried the open source SL-King Oracle provider? Lots of people
> are using this sucessfully with Oracle.
> http://www.sl-king.com/fdooracle/fdooracle.html
> It might still be a MapGuide problem though (I have no idea what type 8
> would be... what SQL type is your identity column?).
> Regardless, you may also want to submit a problem report under your
> Autodesk subscription.
> Jason
> -----Original Message-----
> From: Michael L.
> Subject: [mapguide-users] search error: "Identity property type
> I'm working with MapGuide Enterprise and Studio 2008 German Edition in
> combination with Oracle 10g. Everytime I try to use the MapGuide
> internal search function I get this Error: "Identity property type not
> supported yet (8)" or "No Matches".
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/search-error%3A-%22Identity-property-type-not-supported-yet-%288%29%22-tp14435851s16610p14443394.html
