[mapguide-users] Generating tiles for google maps
azpublic
azpublic at bluewin.ch
Fri Dec 21 14:29:34 EST 2007
George,
Did you try the "IsValid" utility in the mapagent / Web Tier test web
interface ?
I tried to validate the WKT provided by Kori and the validation seems to
fail ...
Do you get the same kind of error ?
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of George McLean
Sent: jeudi, 20. décembre 2007 21:29
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Generating tiles for google maps
Thanks Kori,
I tried this projection but I still get an exception error when I try
and open the map created in MG Studio. There is a coordinate system
field in the Map Editor form in MG Studio. Maybe I have to add this
projection to the list of available projections? Does anyone know how to
add projections to MG Studio?
George
Kori Maleski wrote:
> I think this is the one.
> Details in the link that follows:
> PROJCS["Mercator Spheric", GEOGCS["WGS84basedSpheric_GCS",
> DATUM["WGS84basedSpheric_Datum", SPHEROID["WGS84based_Sphere", 6378137,
0],
> TOWGS84[0, 0, 0, 0, 0, 0, 0]], PRIMEM["Greenwich", 0, AUTHORITY["EPSG",
> "8901"]], UNIT["degree", 0.0174532925199433, AUTHORITY["EPSG", "9102"]],
> AXIS["E", EAST], AXIS["N", NORTH]], PROJECTION["Mercator"],
> PARAMETER["False_Easting", 0], PARAMETER["False_Northing", 0],
> PARAMETER["Central_Meridian", 0], PARAMETER["Latitude_of_origin", 0],
> UNIT["metre", 1, AUTHORITY["EPSG", "9001"]], AXIS["East", EAST],
> AXIS["North", NORTH]]
http://www.sharpgis.net/2007/07/27/TheMicrosoftLiveMapsAndGoogleMapsProjecti
> on.aspx
> ________________________________
> Kori Maleski
> Senior Application Developer
> WEBSOFT DEVELOPERS, INC.
> P: (530) 759-8754 ext 114
> F: (530) 759-0923
> kori.maleski at websoftdev.com
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Thursday, December 20, 2007 8:01 AM
> Thanks for the suggestions. I tried removing quotes and using CDATA but
> have not had any success yet. I think the quotes are not problem. I
> tried another projection from another map and it worked fine. The XML of
> the working file is below.
> <CoordinateSystem>
PROJCS["WORLD-MERCATOR",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137
.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295
]],PROJECTION["Mercator_1SP"],PARAMETER["false_easting",0.000],PARAMETER["fa
lse_northing",0.000],PARAMETER["central_meridian",0.00000000000000],PARAMETE
R["standard_parallel_1",0.00000000000000],PARAMETER["latitude_of_origin",0.0
> 0000000000000],UNIT["Meter",1.00000000000000]]
> </CoordinateSystem>
> <Extents>
> <MinX>0</MinX>
> <MaxX>0</MaxX>
> <MinY>0</MinY>
> <MaxY>0</MaxY>
> </Extents>
> <BackgroundColor>FFFFFFFF</BackgroundColor>
> <Metadata />
> </MapDefinition>
> I think there must be something in the coordinate definition that does
> not work.
> <CoordinateSystem>
> PROJCS["unnamed",GEOGCS["unnamed
ellipse",DATUM["unknown",SPHEROID["unnamed",6378137,0]],PRIMEM["Greenwich",0
],UNIT["degree",0.0174532925199433]],PROJECTION["Mercator_2SP"],PARAMETER["s
tandard_parallel_1",0],PARAMETER["central_meridian",0],PARAMETER["false_east
ing",0],PARAMETER["false_northing",0],UNIT["Meter",1],EXTENSION["PROJ4","+pr
> oj=merc
> +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0
> +units=m +nadgrids=@null +wktext +no_defs"]]
> </CoordinateSystem>
> I need to educate myself on the parameters in these WKT coordinate
> definitions.
> Thanks again for the help,
> George
> Jason Birch wrote:
>> I think that you may either need to change your " to " ... or maybe
>> use something like
>> <![CDATA[
>> h",0],UNIT["degree",0.0174532925199433]],PROJECTION["Mercator_2SP"],PARA
>> METER["standard_parallel_1",0],PARAMETER["central_meridian",0],PARAMETER
>> ["false_easting",0],PARAMETER["false_northing",0],UNIT["Meter",1],EXTENS
>> ION["PROJ4","+proj=merc
>> I have no idea whether either will work though... haven't tried this
>> with MapGuide.
>> Jason
>> From: George McLean
>> I have have been trying to modify my map using mapagent. I have exported
>> the resource content and then edited the coordinate system to use the
>> WKT representation of the projection. I can not seem to get past an
>> error in the Metadata tag:
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.503 / Virus Database: 269.17.4/1189 - Release Date: 18.12.2007
21:40
No virus found in this outgoing message.
21:40
