[mapguide-users] Generating tiles for google maps
azpublic
azpublic at bluewin.ch
Wed Dec 19 13:31:45 EST 2007
Yes it is a mercator projection and its the one I've been using for my map.
Here is a good post about the subject.
http://cfis.savagexi.com/articles/2006/05/03/google-maps-deconstructed
What do you mean by "I would create the box and
then zoom to the corners" ?
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of George McLean
Sent: mercredi, 19. décembre 2007 17:26
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Generating tiles for google maps
I have been trying to get this working as well. My approach has been to
use data between 85 degrees north and 85 degrees south in a Mercator
projection since this is what I believe Google maps uses. I am still not
sure if this is the right approach as I am still working on it.
To get the tiles within your bounding box, I would create the box and
then zoom to the corners. The tiles for that region will be created and
this will help you figure out the rows and columns for each corner at
each zoom level. Once you know the zoom levels and row/column boundaries
you can specify these parameters in the call to the tiling engine.
George McLean
azpublic wrote:
> Hi,
> Im looking for a way to generate custom tiles for google maps or Ms
> Live maps / Virtual earth using Mapguide OS.
> Ive created my map using studio and Im now thinking about using the
> Automated tiling engine from WSD to generate the tiles.
> My main problem is about which scale to use to have my custom tiles
> match with google maps tiles. What are the mapguide scales I need to
> use for specific google maps zoom levels?
> Moreover I want to generate tiles only for a specific lat/lon bounding
> box. Is this possible using the Tiling engine?
> Any help appreciated !
> No virus found in this outgoing message.
> Checked by AVG Free Edition.
> Version: 7.5.503 / Virus Database: 269.17.4 - Release Date: 16.12.2007
> 00:00
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> No virus found in this incoming message.
> Version: 7.5.503 / Virus Database: 269.17.4/1188 - Release Date:
12/17/2007 2:13 PM
Version: 7.5.503 / Virus Database: 269.17.4 - Release Date: 16.12.2007 00:00
