[mapguide-users] Generating tiles for google maps
George McLean
gmclean at gorge.net
Wed Dec 19 14:57:05 EST 2007
I was thinking you could create a layer that was your bounding box and
then add your map to a weblayout. Open the web layout in a browser and
as you zoom in to the corners of your bounding box the tiles will get
created under the TileCache directory (at least in windows). There may
be a better way to do this but that is how I have created tiles for
regions within a larger map.
Thanks for the Chris Savage link. I read it a few weeks ago but now that
I have been working on this it was helpful to re-read.
George
azpublic wrote:
> Yes it is a mercator projection and it’s the one I've been using for my map.
> Here is a good post about the subject.
> http://cfis.savagexi.com/articles/2006/05/03/google-maps-deconstructed
> What do you mean by "I would create the box and
> then zoom to the corners" ?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of George McLean
> Sent: mercredi, 19. décembre 2007 17:26
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Generating tiles for google maps
> I have been trying to get this working as well. My approach has been to
> use data between 85 degrees north and 85 degrees south in a Mercator
> projection since this is what I believe Google maps uses. I am still not
> sure if this is the right approach as I am still working on it.
> To get the tiles within your bounding box, I would create the box and
> then zoom to the corners. The tiles for that region will be created and
> this will help you figure out the rows and columns for each corner at
> each zoom level. Once you know the zoom levels and row/column boundaries
> you can specify these parameters in the call to the tiling engine.
> George McLean
> azpublic wrote:
>> Hi,
>> I’m looking for a way to generate custom tiles for google maps or Ms
>> Live maps / Virtual earth using Mapguide OS.
>> I’ve created my map using studio and I’m now thinking about using the
>> Automated tiling engine from WSD to generate the tiles.
>> My main problem is about which scale to use to have my custom tiles
>> match with google maps tiles. What are the mapguide scales I need to
>> use for specific google maps zoom levels?
>> Moreover I want to generate tiles only for a specific lat/lon bounding
>> box. Is this possible using the Tiling engine?
>> Any help appreciated !
>> No virus found in this outgoing message.
>> Checked by AVG Free Edition.
>> Version: 7.5.503 / Virus Database: 269.17.4 - Release Date: 16.12.2007
>> 00:00
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> No virus found in this incoming message.
>> Version: 7.5.503 / Virus Database: 269.17.4/1188 - Release Date:
> 12/17/2007 2:13 PM
> Version: 7.5.503 / Virus Database: 269.17.4 - Release Date: 16.12.2007 00:00
