[mapguide-users] MapGuide 1.2 login error
uXuf yousuf.hassan at gmail.com
Thu Dec 27 17:29:51 EST 2007
Indeed. I worked around the limitation by setting myself a static IP address
for my notebook. Its not very intuitive though, and could be real pain for
those who move around a lot.
But then, how many of us roam around with a dev machine?
uXuf
JasonBirch wrote:
> No, it's definitely not in the 1.2 release.  That submission was made in
> November.
> Jason
> ________________________________
> From: mapguide-users-bounces at lists.osgeo.org on behalf of uXuf
> Sent: Wed 2007-12-26 3:05 AM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] MapGuide 1.2 login error
> Hi Jason,
> Last night I got exactly the same bug as specified in the changeset, i.e.
> Web Extensions cannot connect to Server when machine is disconnected from
> network. Earlier what I was getting was a side-effect of the above
> problem.
> It's still happening at my end. If it's fixed then it's not reflected in
> the
> 1.2 release.
> uXuf
> JasonBirch wrote:
>> I think that it may have already been fixed in the 1.2.x branch.
>> http://trac.osgeo.org/mapguide/changeset/2509
>> I can't find where/if this change got applied to current 2.0.x trunk...
>> Jason
>> -----Original Message-----
>> From: uXuf
>> Subject: Re: [mapguide-users] MapGuide 1.2 login error
>> Okay so the real culprit appears to be the Wireless Access Point
>> assigning "new" IP address to the system whenever it comes out of
>> stand-by. It seems that MG 1.2 picks up the actual IP address of the
>> system when it initializes the service on system boot-up, while MG 1.1
>> used localhost (or 127.0.0.1) all along. So with 1.2 whenever the system
>> gets a new IP, the service refuses to connect.
>> Figures that Studio connects through all this mess, because I usually
>> use localhost as the server to connect to.
>> Couldn't really see that this would get fixed anytime soon, but really
>> hope that it does because as far as I see it would be a rather simple
>> fix.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/MapGuide-1.2-login-error-tp14398948s16610p14501291.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/MapGuide-1.2-login-error-tp14398948s16610p14519559.html
