[mapguide-users] Base64 decoding process
Jim O'Leary
joleary.public at gmail.com
Fri Dec 28 17:55:58 EST 2007
I'm trying to figure out the Base64 decoding process that MapGuide uses
to store the user's selections on the map.
When I select a given parcel in Sheboygan, the Properties pane tells me
FeatId = 11430
When I capture the selection XML for this feature, it gives me the
the ID tag as
<ID>piwAAA==</ID>
I break down this Base64-encoded string as follows, using a Base64
translation table:
p = 41 = 101001
i = 34 = 100010
w = 48 = 100000
Putting those three 6 bit binary numbers in one line yields
101001 100010 100000
I am assuming that the A characters represent 0, or no valid bits.
Recombining these three 6 bit binary numbers into 8 bit numbers yields
10100110 00101000 00
Turning these binary numbers in decimal yields
10100111 = 166
00101000 = 40
Here I am lost. How does 166 and 40 equate to 11430, which is the FeatId
that this Base64-encoded string evaluates to?
Thanks
View this message in context: http://www.nabble.com/Base64-decoding-process-tp14532589s16610p14532589.html
