[mapguide-users] Base64 decoding process
Traian Stanev
traian.stanev at autodesk.com
Sat Dec 29 01:02:29 EST 2007
First of all, w = 48 = 110000, not 100000.
Then "piw" => 101001 100010 110000 => 1010 0110 0010 1100 => A6 2C => 2C A6 (little endian byte order) => 11430.
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jim O'Leary
Sent: Friday, December 28, 2007 5:56 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Base64 decoding process
I'm trying to figure out the Base64 decoding process that MapGuide uses
to store the user's selections on the map.
When I select a given parcel in Sheboygan, the Properties pane tells me
FeatId = 11430
When I capture the selection XML for this feature, it gives me the
the ID tag as
<ID>piwAAA==</ID>
I break down this Base64-encoded string as follows, using a Base64
translation table:
p = 41 = 101001
i = 34 = 100010
w = 48 = 100000
Putting those three 6 bit binary numbers in one line yields
101001 100010 100000
I am assuming that the A characters represent 0, or no valid bits.
Recombining these three 6 bit binary numbers into 8 bit numbers yields
10100110 00101000 00
Turning these binary numbers in decimal yields
10100111 = 166
00101000 = 40
Here I am lost. How does 166 and 40 equate to 11430, which is the FeatId
that this Base64-encoded string evaluates to?
Thanks
View this message in context: http://www.nabble.com/Base64-decoding-process-tp14532589s16610p14532589.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
