[mapguide-users] FW: Problems while labeling polylines
uXuf
yousuf.hassan at gmail.com
Sat Dec 29 07:40:57 EST 2007
Oh, and as far as your "...fix the position of the label to the exact center
of the polyline..." is concerned, you can specify the label's position by
styling it's "Vertical alignment" to Halfline. You'll find that attribute in
the FeatureLabel->Style Label form.
Regards,
uXuf
azpublic wrote:
> Hi again,
> I’m having some trouble correctly labeling some street level polylines. I
> get some upside down labels or sometimes the labels don’t have the same
> size
> as other for no apparent reason …
> I included a screenshot of my generated map.
> You will see that some labels start correctly and end up upside down. Some
> other are much bigger than others … etc ..
> How is it possible to avoid that?
> For example fix the size of the font and also fix the position of the
> label
> to the exact center of the polyline …
> Thanks for your help !
> No virus found in this outgoing message.
> Checked by AVG Free Edition.
> Version: 7.5.516 / Virus Database: 269.17.11 - Release Date: 27.12.2007
> 00:00
> 00:00
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/FW%3A-Problems-while-labeling-polylines-tp14525210s16610p14537154.html
