[mapguide-users] FW: Problems while labeling polylines
azpublic azpublic at bluewin.ch
Mon Dec 31 00:08:10 EST 2007
Thanks Maksim, uXuf and Traian
I am not sure I understand correctly the NaN part ...
Do you guys suggest I create a layer with composite lines WITHOUT labels,
and then a second layer with only the labels displayed ?
I'll try that right away.
Let me know if didn't understand correctly.
Cheers
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: dimanche, 30. décembre 2007 23:33
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] FW: Problems while labeling polylines
For your item 3:
3) To get it looking GoogleMaps-alike, you'll have to use at least two
separate layers: one for borders, the other (one pixel narrower, above it)
for continuous fill. In my case, both of them are stored in base layer
group.
You do not need to use separate layers to achieve this style. You can use a
composite line style, consisting of two thick lines (one 2 pixels thicker
than the other) to achieve the same effect. MapGuide has code to detect this
situation and automatically render so that the result looks the same as what
you have on the picture.
For item 4:
4) Road labels (street names) were generated dinamically, they're not part
of base layer group. It turns out that they're best fit that way, don't
overlap too much and never get displayed upside-down.
This is actually a good idea -- using dynamic overlay labels allows the
labeling algorithm more freedom when placing labels (as opposed to when
labeling tiles in a base layer) and it is more likely to get it right,
especially when it has to stitch up line segments that make up the same
street so that it can label them together (it makes up what you call NaN on
the fly).
Traian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Maksim Sestic
Sent: Saturday, December 29, 2007 8:32 AM
Subject: Re: [mapguide-users] FW: Problems while labeling polylines
Road network stylization sometimes turns out to be a challenging task,
especially if you have Google Maps in mind. Take a look at the attachment,
and the steps to reproduce visuals/behaviour:
1) First of all, you need to prepare your network topology in a NaN fashion
(Node-Arc-Node), and stick to that rule: roads are continuos LineStrings, if
there's a crossing - LineString ends. Each arc in a topology needs to get
properly coded (road code) and named.
2) Road network represents a layer being updated rarely (more or less), so
it's one of the candidates for one of the base layer groups.
group.
I hope this helps.
Regards,
Maksim Sestic
http://www.nabble.com/file/p14537519/ROADS.jpg
View this message in context:
http://www.nabble.com/FW%3A-Problems-while-labeling-polylines-tp14525210s166
10p14537519.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.516 / Virus Database: 269.17.11 - Release Date: 27.12.2007
00:00
No virus found in this outgoing message.
00:00
