[mapguide-users] Dynamic MapDefinition and Google Earth
Ivan Milicevic
Ivan.Milicevic at supranet.hr
Mon Dec 31 09:49:11 EST 2007
Hi Michael,
I think that I have solution for your problem.
//here, you create new connection to the mapguide server and
creates NEW mgSessionId
MapGuideApi.MgInitializeWebTier(@"C:\program
files\MapguideOpenSource\WebServerExtensions\www\webconfig.ini");
MgUserInformation userInfo = new
MgUserInformation("Administrator", "admin");
MgSite site = new MgSite();
site.Open(userInfo);
String mgSessionId = site.CreateSession();
MgUserInformation userInfoNew = new
MgUserInformation(mgSessionId);
MgSiteConnection siteConnection= new MgSiteConnection();
siteConnection.Open(userInfoNew);
MgResourceService resourceSrvc
=(MgResourceService)siteConnection.CreateService(MgServiceType.ResourceS
ervice);
MgMap map = new MgMap();
//here, you specify a path to the NEW map
MgResourceIdentifier resId = new
MgResourceIdentifier("Library://PROJEKTI/ZLZ/MAPE/ZDENCI.MapDefinition")
String mapName = resId.GetName();
map.Create(resourceSrvc, resId, mapName);
With this code you can change existing map in viewer.
Happy hollydays!
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Michael L.
Sent: Sunday, December 30, 2007 9:13 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Dynamic MapDefinition and Google Earth
Hello,
I'd like to publish various layers from my map to Google Earth.
Therefore I
try to create
a dynamic map where all layers will be saved. This works so far, but for
some
reasons I'm not able to export my map to KML.
The problem is what do I have to enter for MAPDEFINITION?
header("Location:
http://localhost/mapguide2008/mapagent/mapagent.fcgi?OPERATION=GetMapKml
&VERSION=1.0.0&MAPDEFINITION=[?????????]&FORMAT=KML&LOCALE=de");
The static path 'Library://map/town_google.MapDefinition' is not working
because the map is only available during the session. I've already tried
to
use the MgSessionID, as well.
But then I got the Error, that this is no String.
It would be great if someone could help me.
Thanks in advance.
Michael
View this message in context:
http://www.nabble.com/Dynamic-MapDefinition-and-Google-Earth-tp14550671s
16610p14550671.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071231/545aecec/attachment.html
