[mapguide-users] King Oracle Provider Version 0.5.1
Joel Carranza jec at gatekeeper.com
Thu Feb 1 12:00:58 EST 2007
I'm using a 10.2 Oracle Client. However, I connected to a Oracle 9.2
database. Is this supported?
Webo wrote:
> Which Oracle Client do you use? OC 10.2 is required for KingOracle. Read this
> file (if you didn't):
> http://www.sl-king.com/fdooracle/download/README.txt
> Vedad
> Joel Carranza wrote:
>> I suspect I found the problem. The problem only occurs on layers using
>> the Oracle 9.2 instance. Our 10g instance works as expected.
>> Joel
>> Webo wrote:
>>> Hi Joel,
>>> I'm using King.Oracle provider 0.5.1 and the MGOS 1.1.0 without any
>>> problems. I made SQL trace and found that this provider uses spatial
>>> predicate SDO_ANYINTERACT.
>>> I also upgraded MGOS 1.0.1 with this one (1.1.0) which uses FDO 3.2 and
>>> it
>>> works same for me.
>>> Vedad
>>>> Yes. I got a squeaky clean and new version of everything. No problems
>>>> with layer setup or anything like that. However, when I go and try and
>>>> view the map.... Everything just tanks. Oracle logs show that there is
>>>> no spatial predicate on table
>>>> Andy Morsell wrote:
>>>>> Did you get the latest version of the provider (version 0.5.1) which is
>>>>> based on FDO 3.2 which is what MGOS 1.1.0 is now using?
>>>>> Andy
>>>>> -----Original Message-----
>>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Joel
>>>>> Carranza
>>>>> Sent: Tuesday, January 30, 2007 5:08 PM
>>>>> To: MapGuide Users Mail List
>>>>> Subject: [mapguide-users] King Oracle Provider Version 0.5.1
>>>>> I have upgraded to Mapguide 1.1 and found that my King Oracle Provider
>>>>> is
>>>>> no
>>>>> longer working properly. It does not appear to be applying a spatial
>>>>> predicate on map requests, and thus quickly bog down with the volume of
>>>>> data
>>>>> returned. Anyone experinced similair problems? Am I missing something?
>>>>> -Joel
>>>>> Gatekeeper Systems
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070201/9340f011/attachment-0001.html
