[mapguide-users] King Oracle Provider Version 0.5.1
Haris Kurtagic haris at sl-king.com
Thu Feb 1 13:04:31 EST 2007
Hi Joel,
It should work with 9.2. I will check about spatial predicate as you
mantioned.
I think I read in this mailing list that there is a problem with 9.1, I
haven't tested 9.1 but I will do that also.
Haris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Joel
Carranza
Sent: 1. februar 2007 18:01
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] King Oracle Provider Version 0.5.1
I'm using a 10.2 Oracle Client. However, I connected to a Oracle 9.2
database. Is this supported?
Webo wrote:
Which Oracle Client do you use? OC 10.2 is required for KingOracle. Read
this
file (if you didn't):
http://www.sl-king.com/fdooracle/download/README.txt
Vedad
Joel Carranza wrote:
	I suspect I found the problem. The problem only occurs on layers
using
	the Oracle 9.2 instance. Our 10g instance works as expected.
	Joel
	Webo wrote:
		Hi Joel,
		I'm using King.Oracle provider 0.5.1 and the MGOS 1.1.0
without any
		problems. I made SQL trace and found that this provider
uses spatial
		predicate SDO_ANYINTERACT.
		I also upgraded MGOS 1.0.1 with this one (1.1.0) which
uses FDO 3.2 and
		it
		works same for me.
		Vedad
			Yes. I got a squeaky clean and new version of
everything. No problems
			with layer setup or anything like that. However,
when I go and try and
			view the map.... Everything just tanks. Oracle
logs show that there is
			no spatial predicate on table
			Andy Morsell wrote:
				Did you get the latest version of the
provider (version 0.5.1) which is
				based on FDO 3.2 which is what MGOS
1.1.0 is now using?
				Andy
				-----Original Message-----
				Carranza
				Sent: Tuesday, January 30, 2007 5:08 PM
				Subject: [mapguide-users] King Oracle
				I have upgraded to Mapguide 1.1 and
found that my King Oracle Provider
				is
				no
				longer working properly. It does not
appear to be applying a spatial
				predicate on map requests, and thus
quickly bog down with the volume of
				data
				returned. Anyone experinced similair
problems? Am I missing something?
				-Joel
				jec at gatekeeper.com
				Gatekeeper Systems
				mapguide-users mailing list
				mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070201/4f393dcc/attachment-0001.html
