[mapguide-users] Connecting to Mapguide
Tim Carr ttc at GoColumbiaMO.com
Fri Feb 2 11:04:00 EST 2007
I wanted to thank everyone for the help last night on this problem. I
finally got it to connect and start working. I am now going to try and
read read and read more so I can figure out how to use it now :-)
Tim Carr
>>> "Jason Birch" <Jason.Birch at nanaimo.ca> 2/1/2007 4:41 PM >>>
Try the following:
1. Install SP3 for Map
2. rename Autodesk.MapGuide.Studio.Site.dll in your main Map directory
to *.bak
3. replace it with
http://download.osgeo.org/mapguide/patches/mapguidestudio/1.1.0/Autodesk
.MapGuide.Studio.Site.PatchedDLL.zip
Jason
who said something about not supporting Map on this email list :)
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Tim Carr
Sent: Thursday, February 01, 2007 14:30
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Connecting to Mapguide
I hit go
then get the log in box
I then enter
Administrator for user name
and
admin for password.
That is when I get the can not connect to site popup.
I currently do not have service packs installed  on this laptop. Do
you
feel that this could be a problem?
>>> "James H. Murphy" <jhm at alacad.com> 2/1/2007 4:25 PM >>>
Ok and when you click go after entering http://localhost:8008/mapguide
for the site name and asks for the user and password you only get a
can't connect to site error?  Do you have SP3 for Map installed?
James Murphy
Applications Engineer
ALACAD
 (205)444-3100
Visit us at www.alacad.com
Sent: Thursday, February 01, 2007 4:14 PM
Under the display manager it says publish to mapguide. Then under the
tool button in that palette I click publish to mapguide. That is when
it
asks for the address to publish to site... that is when I am unable to
do so.
I guess what I should do is also lay down some ground work of what I
am
trying to do. I have a collection of about 10 drawing with about
20,000
objects in each one. Each one of these objects have a stored value
called gis_id. That value is stored as XData. I then have a MDB that
has
that gis_id. I need to be able to easily create a map in mapguide that
when you click on a object you can view that data that is stored in
that
record. I don't know if there is a better or easier way to approach
what
I am trying to do or not.
Tim Carr
>>> "James H. Murphy" <jhm at alacad.com> 2/1/2007 4:03 PM >>>
The only connection from the display manager in Map is to publish to
mapguide. Are you trying to connect from the Data Connection (FDO)
palette?
James Murphy
ALACAD
 (205)444-3100
Sent: Thursday, February 01, 2007 3:38 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Connecting to Mapguide
Ok, let me start out by saying I am very new to this and I feel
uneducated for even asking this. But I have a copy of MGOS installed
on
the laptop and was able to load the sample package fine and was able
to
view it. I am now using Map 2007 and trying to connect to the Mapguide
server that resides on the same lap top. When in the display manager
in
Map2007 it asked for the URL to connect to the site. When I type in
http://localhost:8008/ it will not connect. I have tried adding
Mapguide
mapguide/admin and every combination that I can think of to connect to
it. I have also tried typing in the IP of the laptop with the same
error
of "failed to connect to site." If anyone could please try and point
me
in the correct direction I would really appreciate it. I have tried to
read as much as I can about this and a lot of it seems to be above
where
my experience resides with this. I am trying to learn but I am still
looking for places to read about the more elementary areas of the
program since this is my first experience with Mapguide of any
version.
Thank you
Tim Carr
City of Columbia
Water and Light
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.432 / Virus Database: 268.17.19/663 - Release Date:
2/1/2007 2:28 PM
No virus found in this outgoing message.
2/1/2007 2:28 PM
2/1/2007 2:28 PM
2/1/2007 2:28 PM
