[mapguide-users] Connecting Non Spatial Oracle Data to
MapDataProperties?
Haris Kurtagic
haris at sl-king.com
Fri Feb 2 14:10:59 EST 2007
Hi Scott,
You can also:
1. install free Oracle XE
export SDF to Oracle XE
create database link to existing Oracle DB
create View linking geometry with other attributes
2. export SDF to existing Oracle DB
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: 2. februar 2007 19:29
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Connecting Non Spatial Oracle Data to
MapDataProperties?
You need to create a resource using an ODBC connection to the Oracle
database.
Then you can can do a join from your SDF resource to the Oracle
resource.
Regards,
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Scott
Reisdorf
Sent: Friday, February 02, 2007 11:27 AM
Subject: [mapguide-users] Connecting Non Spatial Oracle Data to Map
DataProperties?
All,
I have an SDF file Layer loaded into MapGuide and I would like to link a
property from the file to an outside Oracle Database (non spatial) to
retrieve additional properties.
Is this possible using the Oracle King Provider or using some other
mechanism?
Any help is appreciated.
Thanks,
-scott
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
