[mapguide-users] Selecting a feature through PHP
Paul Spencer
pspencer at dmsolutions.ca
Sat Feb 3 11:59:32 EST 2007
Its not obvious, but you need to save the selection:
$selection->Save($resourceService, $mapName);
Cheers
Paul
On 31-Jan-07, at 4:58 PM, George McLean wrote:
> Hello,
> I have a php page the allows the user to enter some search criteria
> and then to zoom to a feature based on the search results. This
> seems to work pretty well by passing coordinates and zoom scale to
> the ZoomToView function. What I would like to do is highlight the
> selected feature so it is obvious which feature was selected. I
> thought I could add the feature to a selection set and it would
> show up as highlighted. So far I have not been able to get this to
> work.
> My first question would be is this the best approach to highlight a
> feature?
> If so, the following code snippet shows how I am attempting to add
> the feature to a selection set so it will be highlighted, maybe
> someone will have some insight as to why it is not working (or a
> better way to do this!).
> Thanks in advance.
> George
> $agfReaderWriter = new MgAgfReaderWriter();
> $aSelection = new MgSelection($map);
> $bFound = 0;
> while ($featureReader->ReadNext())
> $val = $featureReader->GetGeometry('geometry');
> if ($val != NULL) {
> $aGeometry = $agfReaderWriter->Read($val);
> $aPoint = $aGeometry->GetCentroid();
> $aCoord = $aPoint->GetCoordinate();
> $x = $aCoord->GetX();
> $y = $aCoord->GetY();
> $aResourceId = new MgResourceIdentifier
> ("Library://MapGuideStudio/Layers/Meters.LayerDefinition");
> $aLayer = new MgLayer($aResourceId,
> $resourceService);
> $aSelection->AddFeatures($aLayer, $featureReader,
> 1);
> $aLayer->ForceRefresh();
> $bFound = 1; // found
> coordinates } else {
> echo "This geometry property is null <br>";
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
