[mapguide-users] RE: ODBC Provider with SQL Server 2005: Does it
worksfor somebody?
FGoulet
gouletf at dfo-mpo.gc.ca
Mon Feb 5 08:51:20 EST 2007
Sure,
Here's the script:
USE [DredgingRegister]
GO
/****** Object: Table [dbo].[Dredging_Activity] Script Date: 01/31/2007
14:53:46 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
CREATE TABLE [dbo].[Dredging_Activity](
[Activity_ID] [int] IDENTITY(1,1) NOT NULL,
[UserName] [nvarchar](256) COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[Location_FR] [nvarchar](32) COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[Location_EN] [nvarchar](32) COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[Description_FR] [nvarchar](32) COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[Description_EN] [nvarchar](32) COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[Start_Date] [datetime] NULL,
[Finish_Date] [datetime] NULL,
[Dredging_Type_CD] [int] NULL,
[Material_Quantity] [numeric](9, 3) NULL,
[Material_Disposal] [nchar](10) COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[Longitude] [float] NULL,
[Latitude] [float] NULL,
[Registration_Date] [datetime] NULL,
[Approved] [bit] NULL,
[Proponent_ID] [int] NULL,
[Responsible_ID] [int] NULL,
CONSTRAINT [PK_Dredging_Activity] PRIMARY KEY CLUSTERED
[Activity_ID] ASC
)WITH (PAD_INDEX = OFF, IGNORE_DUP_KEY = OFF) ON [PRIMARY]
) ON [PRIMARY]
GO
ALTER TABLE [dbo].[Dredging_Activity] WITH CHECK ADD CONSTRAINT
[FK_Dredging_Activity_Contact] FOREIGN KEY([Responsible_ID])
REFERENCES [dbo].[Contact] ([Contact_ID])
GO
ALTER TABLE [dbo].[Dredging_Activity] CHECK CONSTRAINT
GO
[FK_Dredging_Activity_Dredging_Type] FOREIGN KEY([Dredging_Type_CD])
REFERENCES [dbo].[Dredging_Type] ([Dredging_Type_CD])
GO
GO
[FK_Dredging_Activity_Proponent] FOREIGN KEY([Proponent_ID])
REFERENCES [dbo].[Proponent] ([Proponent_ID])
GO
The columns mapped to X and Y in MG Studio are Longitude and Latitude. I
tried with others numeric type (real, decimal, numeric) and I always get
that error.
Thanks
JasonBirch wrote:
> Frederic wrote:
> An exception occurred in FDO component.
> RDBMS: Incompatible column type
> Care to share the table definition? The problem with ODBC is that it's
> not generic enough :)
> Jason
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/ODBC-Provider-with-SQL-Server-2005%3A-Does-it-works-for-somebody--tf3144880s16610.html#a8806498
