[mapguide-users] RE: ODBC Provider with SQL Server 2005: Does it
	worksfor somebody?
    pdtechguy
    patroam at gmail.com
    Wed Feb 14 01:27:18 EST 2007
It works very good for an avl map that I created as a tech demo. It's is
displaying 30'ish moving points on a street level tiled base map of our
county. Be happy to share any info you'd like.
BTW thanks to all who participate in this project.
Here is the sql table that contains the points I am using:
USE [AVL_CAD]
GO
/****** Object:  Table [dbo].[avl_last_known]    Script Date: 02/13/2007
22:26:43 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
CREATE TABLE [dbo].[avl_last_known](
	[servertimestamp] [datetime] NULL,
	[cadunit1] [text] COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
	[cadunit2] [text] COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
	[caduser] [text] COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
	[gpstimeofday] [text] COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
	[lattitude] [float] NULL,
	[longitude] [float] NULL,
	[speed] [text] COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
	[heading] [text] COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
	[sourceofdata] [text] COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
	[ageofdata] [text] COLLATE SQL_Latin1_General_CP1_CI_AS NULL
) ON [PRIMARY] TEXTIMAGE_ON [PRIMARY]
FGoulet wrote:
> Sure,
> Here's the script:
> USE [DredgingRegister]
> GO
> /****** Object:  Table [dbo].[Dredging_Activity]    Script Date:
> 01/31/2007 14:53:46 ******/
> SET ANSI_NULLS ON
> GO
> GO
> CREATE TABLE [dbo].[Dredging_Activity](
> 	[Activity_ID] [int] IDENTITY(1,1) NOT NULL,
> 	[UserName] [nvarchar](256) COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
> 	[Location_FR] [nvarchar](32) COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
> 	[Location_EN] [nvarchar](32) COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
> 	[Description_FR] [nvarchar](32) COLLATE SQL_Latin1_General_CP1_CI_AS
> NULL,
> 	[Description_EN] [nvarchar](32) COLLATE SQL_Latin1_General_CP1_CI_AS
> NULL,
> 	[Start_Date] [datetime] NULL,
> 	[Finish_Date] [datetime] NULL,
> 	[Dredging_Type_CD] [int] NULL,
> 	[Material_Quantity] [numeric](9, 3) NULL,
> 	[Material_Disposal] [nchar](10) COLLATE SQL_Latin1_General_CP1_CI_AS
> NULL,
> 	[Longitude] [float] NULL,
> 	[Latitude] [float] NULL,
> 	[Registration_Date] [datetime] NULL,
> 	[Approved] [bit] NULL,
> 	[Proponent_ID] [int] NULL,
> 	[Responsible_ID] [int] NULL,
>  CONSTRAINT [PK_Dredging_Activity] PRIMARY KEY CLUSTERED
> 	[Activity_ID] ASC
> )WITH (PAD_INDEX  = OFF, IGNORE_DUP_KEY = OFF) ON [PRIMARY]
> ) ON [PRIMARY]
> GO
> ALTER TABLE [dbo].[Dredging_Activity]  WITH CHECK ADD  CONSTRAINT
> [FK_Dredging_Activity_Contact] FOREIGN KEY([Responsible_ID])
> REFERENCES [dbo].[Contact] ([Contact_ID])
> GO
> ALTER TABLE [dbo].[Dredging_Activity] CHECK CONSTRAINT
> GO
> [FK_Dredging_Activity_Dredging_Type] FOREIGN KEY([Dredging_Type_CD])
> REFERENCES [dbo].[Dredging_Type] ([Dredging_Type_CD])
> GO
> GO
> [FK_Dredging_Activity_Proponent] FOREIGN KEY([Proponent_ID])
> REFERENCES [dbo].[Proponent] ([Proponent_ID])
> GO
> The columns mapped to X and Y in MG Studio are Longitude and Latitude. I
> tried with  others numeric type (real, decimal, numeric) and I always get
> that error.
> Thanks
> JasonBirch wrote:
>> Frederic wrote:
>>         An exception occurred in FDO component.
>>         RDBMS: Incompatible column type
>> Care to share the table definition?  The problem with ODBC is that it's
>> not generic enough :)
>> Jason
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/ODBC-Provider-with-SQL-Server-2005%3A-Does-it-works-for-somebody--tf3144880s16610.html#a8959427
