[mapguide-users] RE: ODBC Provider with SQL Server 2005: Does it worksfor somebody?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Feb 16 08:02:52 EST 2007
Moving points, as in the locations move frequently? Do you have it set
up to refresh the points layer automatically?
Andrew
pdtechguy wrote:
> It works very good for an avl map that I created as a tech demo. It's is
> displaying 30'ish moving points on a street level tiled base map of our
> county. Be happy to share any info you'd like.
> BTW thanks to all who participate in this project.
> Here is the sql table that contains the points I am using:
> USE [AVL_CAD]
> GO
> /****** Object:  Table [dbo].[avl_last_known]    Script Date: 02/13/2007
> 22:26:43 ******/
> SET ANSI_NULLS ON
> GO
> SET QUOTED_IDENTIFIER ON
> GO
> CREATE TABLE [dbo].[avl_last_known](
> 	[servertimestamp] [datetime] NULL,
> 	[cadunit1] [text] COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
> 	[cadunit2] [text] COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
> 	[caduser] [text] COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
> 	[gpstimeofday] [text] COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
> 	[lattitude] [float] NULL,
> 	[longitude] [float] NULL,
> 	[speed] [text] COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
> 	[heading] [text] COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
> 	[sourceofdata] [text] COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
> 	[ageofdata] [text] COLLATE SQL_Latin1_General_CP1_CI_AS NULL
> ) ON [PRIMARY] TEXTIMAGE_ON [PRIMARY]
> FGoulet wrote:
>> Sure,
>> Here's the script:
>> USE [DredgingRegister]
>> GO
>> /****** Object:  Table [dbo].[Dredging_Activity]    Script Date:
>> 01/31/2007 14:53:46 ******/
>> SET ANSI_NULLS ON
>> GO
>> GO
>> CREATE TABLE [dbo].[Dredging_Activity](
>> 	[Activity_ID] [int] IDENTITY(1,1) NOT NULL,
>> 	[UserName] [nvarchar](256) COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
>> 	[Location_FR] [nvarchar](32) COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
>> 	[Location_EN] [nvarchar](32) COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
>> 	[Description_FR] [nvarchar](32) COLLATE SQL_Latin1_General_CP1_CI_AS
>> NULL,
>> 	[Description_EN] [nvarchar](32) COLLATE SQL_Latin1_General_CP1_CI_AS
>> NULL,
>> 	[Start_Date] [datetime] NULL,
>> 	[Finish_Date] [datetime] NULL,
>> 	[Dredging_Type_CD] [int] NULL,
>> 	[Material_Quantity] [numeric](9, 3) NULL,
>> 	[Material_Disposal] [nchar](10) COLLATE SQL_Latin1_General_CP1_CI_AS
>> NULL,
>> 	[Longitude] [float] NULL,
>> 	[Latitude] [float] NULL,
>> 	[Registration_Date] [datetime] NULL,
>> 	[Approved] [bit] NULL,
>> 	[Proponent_ID] [int] NULL,
>> 	[Responsible_ID] [int] NULL,
>>  CONSTRAINT [PK_Dredging_Activity] PRIMARY KEY CLUSTERED
>> 	[Activity_ID] ASC
>> )WITH (PAD_INDEX  = OFF, IGNORE_DUP_KEY = OFF) ON [PRIMARY]
>> ) ON [PRIMARY]
>> GO
>> ALTER TABLE [dbo].[Dredging_Activity]  WITH CHECK ADD  CONSTRAINT
>> [FK_Dredging_Activity_Contact] FOREIGN KEY([Responsible_ID])
>> REFERENCES [dbo].[Contact] ([Contact_ID])
>> GO
>> ALTER TABLE [dbo].[Dredging_Activity] CHECK CONSTRAINT
>> GO
>> [FK_Dredging_Activity_Dredging_Type] FOREIGN KEY([Dredging_Type_CD])
>> REFERENCES [dbo].[Dredging_Type] ([Dredging_Type_CD])
>> GO
>> GO
>> [FK_Dredging_Activity_Proponent] FOREIGN KEY([Proponent_ID])
>> REFERENCES [dbo].[Proponent] ([Proponent_ID])
>> GO
>> The columns mapped to X and Y in MG Studio are Longitude and Latitude. I
>> tried with  others numeric type (real, decimal, numeric) and I always get
>> that error.
>> Thanks
>> JasonBirch wrote:
>>> Frederic wrote:
>>>         An exception occurred in FDO component.
>>>         RDBMS: Incompatible column type
>>> Care to share the table definition?  The problem with ODBC is that it's
>>> not generic enough :)
>>> Jason
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
	*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
