[mapguide-users] New to Map Guide
Faizan Tayyab
Faizan.Tayyab at ordnancesurvey.co.uk
Thu Feb 8 12:16:23 EST 2007
Hi all,
I am new to map Guide. I have a question. Once I have a web layout
created in the Autodesk Studio. How can I publish it so that it is
visible to other users as well. I can view it from Autodesk studio
client viewer but how can make it available to other users.
Thanks
Faizan
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
Sent: 08 February 2007 17:09
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] FDO Build_Thirdparty fails on Ubuntu
Dapper Drake
As far as I can remember, Debian based distributions use slightly
different naming for the .so produced by the compiler. The FDO install
script assumes the name libxalan-c.so.17.0, while the actual name on
Ubuntu is probably something like libxalan-c.17.0. If you find such a
file and manually copy it to the /usr/local/fdo-3.2.0/lib, you may be
able to simply ignore that error. The standard disclaimer that I am just
guessing applies here.
Traian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of joanne cook
Sent: Thursday, February 08, 2007 11:11 AM
Subject: [mapguide-users] FDO Build_Thirdparty fails on Ubuntu Dapper
Drake
I am trying to install MGOS 1.1.0 on an ubuntu dapper drake server. The
FDO build_thirdparty.sh script fails with the error
/usr/bin/install -c -m 644 ./apache/xml-xalan/c/lin/libxalan-c.so.17.0
/usr/local/fdo-3.2.0/lib/apache/xml-xalan/c/lib/libxalan-c.so.17.0
/usr/bin/install: cannot create regular file
/usr/local/fdo-3.2.0/lib/apache/xml-xalan/c/lib/libxalan-c.so.17.0 No
such file or directory
(I've had to type this from hand-written notes, so apologies for any
typos)
Can anyone give me any pointers on solving this? I have a different
version of libxalan installed separately- libxalan110. I can't find an
earlier version for ubuntu, and I thought that the FDO build should
install it's own copy. Have I got a conflict between the two versions?
Thanks
Jo
Joanne Cook BSc MLitt AIFA MBCS
Information Systems Coordinator
Oxford Archaeology North
This message has been scanned for viruses by BlackSpider MailControl -
www.blackspider.com
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
