[mapguide-users] Map Tiled Perfomance
Jason Birch
Jason.Birch at nanaimo.ca
Thu Feb 8 21:56:52 EST 2007
You have 37 layers each on its own base layer in the same map?
Or you have a single base layer with 37 layers in it?
The latter is immeasurably preferred.
If they are already all in a single base layer, you may want to look at auto-generating the tiles.
Certain folks that have already done this internally would be well looked upon if they released their source :)
Jason
Subject: [mapguide-users] Map Tiled Perfomance
currently i have 37 layers in the base layers. and the performance of the
first map tiled loading will take arround 30 seconds. any idea on how to
make it faster in the first map loading?
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070208/a7024585/attachment.bin
