[mapguide-users] Map Tiled Perfomance
Kori Maleski kmale at telus.net
Thu Feb 8 22:46:12 EST 2007
I resemble that remark. :-)
The only way to improve performance without auto-generation is to manually
pan around for each zoom threshold to generate the cache.
We will be releasing a utility to do the auto-generation in the next month
or so.  Still tweaking...
Kori Maleski
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: February 8, 2007 6:57 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Map Tiled Perfomance
You have 37 layers each on its own base layer in the same map?
Or you have a single base layer with 37 layers in it?
The latter is immeasurably preferred.
If they are already all in a single base layer, you may want to look at
auto-generating the tiles.
Certain folks that have already done this internally would be well looked
upon if they released their source :)
Jason
  _____
Subject: [mapguide-users] Map Tiled Perfomance
currently i have 37 layers in the base layers. and the performance of the
first map tiled loading will take arround 30 seconds. any idea on how to
make it faster in the first map loading?
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070208/f11c1ba1/winmail.bin
