[mapguide-users] Linux Install Debian 3.1r4
Chris Gountanis
cgountanis at mpower-tech.com
Fri Feb 9 18:55:13 EST 2007
Seems the AptLinux installer worked fine. I have Apache working on port
8008. Let me know if this can be fixed some how if possible. I am following
the Linux install guides and have all the Linux packages installed
up-to-date.
********** FDO Errors
NetworkLinkFeatureClass.cpp' is in subdirectory
automake: Fdo/Unmanaged/Src/Fdo/Makefile.am: not supported: source file
`Schema/
TopoFeaturePropertyDefinition.cpp' is in subdirectory
`Schema/
TopoGeometryPropertyDefinition.cpp' is in subdirectory
`Schema/
Topology.cpp' is in subdirectory
`Schema/
PropertyValueConstraintList.cpp' is in subdirectory
`Schema/
PropertyValueConstraintRange.cpp' is in subdirectory
`Schema/
UniqueConstraint.cpp' is in subdirectory
`Schema/
UniqueConstraintCollection.cpp' is in subdirectory
`ClientS
ervices/ClientServiceException.cpp' is in subdirectory
`ClientS
ervices/ConnectionManager.cpp' is in subdirectory
`ClientS
ervices/FeatureAccessManager.cpp' is in subdirectory
`ClientS
ervices/Provider.cpp' is in subdirectory
`ClientS
ervices/ProviderCollection.cpp' is in subdirectory
`ClientS
ervices/ProviderNameTokens.cpp' is in subdirectory
`ClientS
ervices/ProviderRegistry.cpp' is in subdirectory
`ClientS
ervices/RegistryUtility.cpp' is in subdirectory
`ClientS
ervices/prefix.cpp' is in subdirectory
`Connect
ions/ConnectionException.cpp' is in subdirectory
`Connect
ions/Capabilities/ArgumentDefinition.cpp' is in subdirectory
`Connect
ions/Capabilities/ArgumentDefinitionCollection.cpp' is in subdirectory
`Connect
ions/Capabilities/FunctionDefinition.cpp' is in subdirectory
`Connect
ions/Capabilities/FunctionDefinitionCollection.cpp' is in subdirectory
`Connect
ions/Capabilities/ReadOnlyArgumentDefinitionCollection.cpp' is in
subdirectory
`Connect
ions/Capabilities/ISchemaCapabilities.cpp' is in subdirectory
`Connect
ions/Capabilities/IExpressionCapabilities.cpp' is in subdirectory
`Connect
ions/Capabilities/SignatureDefinition.cpp' is in subdirectory
`Command
s/BatchParameterValueCollection.cpp' is in subdirectory
`Command
s/CommandException.cpp' is in subdirectory
`Command
s/IdentifierCollection.cpp' is in subdirectory
`Command
s/ParameterValue.cpp' is in subdirectory
`Command
s/ParameterValueCollection.cpp' is in subdirectory
`Command
s/PropertyValue.cpp' is in subdirectory
`Command
s/PropertyValueCollection.cpp' is in subdirectory
`Command
s/Schema/PhysicalSchemaMappingCollection.cpp' is in subdirectory
`Command
s/Schema/PhysicalClassMapping.cpp' is in subdirectory
`Command
s/Schema/PhysicalElementMapping.cpp' is in subdirectory
`Command
s/Schema/PhysicalPropertyMapping.cpp' is in subdirectory
`Command
s/Schema/PhysicalSchemaMapping.cpp' is in subdirectory
`Command
s//SpatialContext/SpatialContextMismatchException.cpp' is in subdirectory
`Parse/y
yExpression.cpp' is in subdirectory
`Parse/y
yFilter.cpp' is in subdirectory
`Parse/L
ex.cpp' is in subdirectory
`Parse/P
arse.cpp' is in subdirectory
`Xml/Cla
`Xml/Cla
ssMappingCollection.cpp' is in subdirectory
`Xml/Con
text.cpp' is in subdirectory
`Xml/Des
erializable.cpp' is in subdirectory
`Xml/Ele
`Xml/Ele
mentMappingCollection.cpp' is in subdirectory
`Xml/Fla
gs.cpp' is in subdirectory
`Xml/Nam
eCollectionHandler.cpp' is in subdirectory
`Xml/Sch
`Xml/Ser
`Xml/SCR
eadHandler.cpp' is in subdirectory
`Xml/Spa
tialContextFlags.cpp' is in subdirectory
`Xml/Spa
tialContextReader.cpp' is in subdirectory
`Xml/Spa
tialContextSerializer.cpp' is in subdirectory
`Xml/Spa
tialContextWriter.cpp' is in subdirectory
`Xml/Fea
tureFlags.cpp' is in subdirectory
`Xml/Fea
tureReader.cpp' is in subdirectory
`Xml/Fea
tureReaderImpl.cpp' is in subdirectory
`Xml/Ass
ociationProperty.cpp' is in subdirectory
`Xml/Box
`Xml/Coo
rdinateGroup.cpp' is in subdirectory
`Xml/Dat
aProperty.cpp' is in subdirectory
`Xml/Fea
tureContext.cpp' is in subdirectory
`Xml/Fea
tureHandler.cpp' is in subdirectory
`Xml/Fea
turePropertyReader.cpp' is in subdirectory
`Xml/Fea
turePropertyReaderImpl.cpp' is in subdirectory
`Xml/Geo
metricProperty.cpp' is in subdirectory
`Xml/Geo
metry.cpp' is in subdirectory
`Xml/Geo
metryHandler.cpp' is in subdirectory
`Xml/Lin
eString.cpp' is in subdirectory
`Xml/Lin
earRing.cpp' is in subdirectory
`Xml/Mul
tiGeometry.cpp' is in subdirectory
`Xml/Mul
tiLineString.cpp' is in subdirectory
`Xml/Mul
tiPoint.cpp' is in subdirectory
`Xml/Mul
tiPolygon.cpp' is in subdirectory
`Xml/Poi
`Xml/Pol
`Xml/Fea
turePropertyWriter.cpp' is in subdirectory
`Xml/Fea
tureSerializer.cpp' is in subdirectory
`Xml/Geo
metrySerializer.cpp' is in subdirectory
`Xml/LpC
lassDefinition.cpp' is in subdirectory
`Xml/LpG
mlElementDefinition.cpp' is in subdirectory
`Xml/LpP
`Xml/LpS
chema.cpp' is in subdirectory
`Xml/Sch
emaManager.cpp' is in subdirectory
`Xml/Fea
tureWriter.cpp' is in subdirectory
automake: Utilities/Common/Makefile.am: not supported: source file
`Src/FdoCommo
nNlsUtil.cpp' is in subdirectory
`Src/FdoCommo
nOSUtil.cpp' is in subdirectory
`Src/FdoCommo
nSchemaUtil.cpp' is in subdirectory
`Src/FdoCommo
nStringUtil.cpp' is in subdirectory
`Src/FdoCommo
nMiscUtil.cpp' is in subdirectory
`Src/FdoCommo
nFile.cpp' is in subdirectory
`Src/FdoCommo
nFilterExecutor.cpp' is in subdirectory
`Src/FdoCommo
nGeometryUtil.cpp' is in subdirectory
`Src/FdoCommo
nConnPropDictionary.cpp' is in subdirectory
`Src/FdoCommo
nConnStringParser.cpp' is in subdirectory
`Src/FdoCommo
nBinaryReader.cpp' is in subdirectory
`Src/FdoCommo
nBinaryWriter.cpp' is in subdirectory
`Src/FdoCommo
nPropertyIndex.cpp' is in subdirectory
`Src/FdoCommo
nQueryAggregator.cpp' is in subdirectory
`Src/FdoCommo
nDataReader.cpp' is in subdirectory
`Src/FdoCommo
nSelectAggregatesCommand.cpp' is in subdirectory
`Src/FdoCommo
nThreadMutex.cpp' is in subdirectory
`Src/FdoCommo
nThreadUtil.cpp' is in subdirectory
`Src/stdafx.c
`Src/Parse/Le
`Src/Parse/Pa
`Src/Parse/yy
Utilities/OWS/Makefile.am:59: invalid unused variable name:
`nodist_EXTRA_libFdo
Ows_la_SOURCES'
********** MapGuide Server / Web Extension Errors
debian:/home/mapguide-1.1.0# ./build_oem.sh > /dev/null
Makefile.am:1: option `nostdinc' not recognized
ansi/Makefile.am:1: option `nostdinc' not recognized
mac/Makefile.am:1: option `nostdinc' not recognized
zip/Makefile.am:1: option `nostdinc' not recognized
x86/Makefile.am:1: option `nostdinc' not recognized
autoreconf: automake failed with exit status: 1
Timer.cpp:126:7: warning: no newline at end of file
package/Makefile.am:1: option `nostdinc' not recognized
package/reader/Makefile.am:1: option `nostdinc' not recognized
package/writer/Makefile.am:1: option `nostdinc' not recognized
package/writer/extensions/Makefile.am:1: option `nostdinc' not recognized
package/writer/extensions/6.0/Makefile.am:1: option `nostdinc' not
recognized
package/writer/extensions/6.01/Makefile.am:1: option `nostdinc' not
recognized
package/utility/Makefile.am:1: option `nostdinc' not recognized
expat/Makefile.am:1: option `nostdinc' not recognized
whiptk/Makefile.am:1: option `nostdinc' not recognized
w3dtk/Makefile.am:1: option `nostdinc' not recognized
w3dtk/utility/Makefile.am:1: option `nostdinc' not recognized
w3dtk/hoops/Makefile.am:1: option `nostdinc' not recognized
publisher/Makefile.am:1: option `nostdinc' not recognized
publisher/impl/Makefile.am:1: option `nostdinc' not recognized
publisher/model/Makefile.am:1: option `nostdinc' not recognized
publisher/plot/Makefile.am:1: option `nostdinc' not recognized
make[5]: avoid-version: Command not found
make[5]: [libdwfpackagewriterextensions.la] Error 127 (ignored)
make[4]: *** No rule to make target
`../../package/writer/extensions/libdwfpacka
gewriterextensions.la', needed by `libdwfpackagewriter.la'. Stop.
make[3]: *** [all-recursive] Error 1
make[2]: *** [all-recursive] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all-recursive-am] Error 2
Seem to get this a lot as well [libFDO.la] Error 127 (ignored)
Regards,
Chris
