[mapguide-users] CPLCleanupListTLS Error (Was RE: LibXerces conflict on Ubuntu Dapper Drake?)
Jo Cook j.cook at OXFORDARCH.CO.UK
Mon Feb 12 05:43:55 EST 2007
Hi Frank,
Many thanks for your response. Unfortunately my inexperience with all things
linux means I have to go away and figure out how to do the things you've
suggested, but in the interim, when I did a simple "find" for instances of
libgdal on my system I couldn't find any instances of libgdal other than
those related to fdo and mapguide opensource. The different versions are as
follows:
/usr/local/fdo-3.2.0/lib/libgdal.so.1.9.0
/home/joc/mapguide-1.1.0/Oem/gdal-1.3.0/.libs/libgdal.so.1.8.0
/home/fdo/OpenSource_FDO/Thirdparty/GDAL1.3/linux/lib/optimized/libgdal.so.1.9.0
I had installed libgdal1c2a and libgdal1-dev from the ubuntu repository but
got rid of them in case there was a conflict.
Hope this is useful, and thanks for your help
Jo
Frank Warmerdam-2 wrote:
> Jo Cook wrote:
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of joanne cook
>>> Sent: Friday, February 09, 2007 9:10 AM
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: [mapguide-users] LibXerces conflict on Ubuntu Dapper Drake?
>>> Hi All,
>>> So I've got through installing the FDO components, and the OEM
>>> components for MGOS 1.1.0, but the final build of the main package is
>>> failing with the following error:
>>> /usr/bin/ld: warning: libxerces-c.so.27, needed by
>>> /home/joc/mapguide-1.1.0/common/Foundation/.libs/libMgFoundation.so, may
>>> conflict with libxerces-c.so.25
>>> /home/joc/MapGudie-1.1.0/Common/CoordinateSystem/.libs/libMgCoordinateSy
>>> stem.so: undefined reference to "CPLCleanupTLS()"
>>> collect2: ld returned 1 exit status
>>> I see that libxerces-c.so.25 is part of the FDO setup, so is there a
>>> conflict between these two versions or is it a completely different
>>> problem?
> Jo,
> I suspect that you are picking up a different version of libgdal.so than
> the one built from Thirdparty.  Perhaps a substantially older one that
> lacks the CPLCleanupTLS() function?  I'd guess it is also linked against
> the distinct version of Xerces.
> I'd suggest digging into the link path for ld, and consider fiddling
> with it to ensure there is an -L to the thirdparty copy of GDAL.
> Showing the whole link command might make it easier for us to offer
> support.
> You also might want to do "ldd libgdal.so" to find other libgdal.so's on
> your system.  If you don't need them, just strip them off.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> mapguide-users mailing list
View this message in context: http://www.nabble.com/LibXerces-conflict-on-Ubuntu-Dapper-Drake--tf3200598s16610.html#a8921964
