[mapguide-users] CPLCleanupListTLS Error (Was RE: LibXerces conflict on Ubuntu Dapper Drake?)
Fri Feb 9 13:19:41 EST 2007
Jo Cook wrote:
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of joanne cook
>> Sent: Friday, February 09, 2007 9:10 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] LibXerces conflict on Ubuntu Dapper Drake?
>> Hi All,
>> So I've got through installing the FDO components, and the OEM
>> components for MGOS 1.1.0, but the final build of the main package is
>> failing with the following error:
>> /usr/bin/ld: warning: libxerces-c.so.27, needed by
>> /home/joc/mapguide-1.1.0/common/Foundation/.libs/libMgFoundation.so, may
>> conflict with libxerces-c.so.25
>> /home/joc/MapGudie-1.1.0/Common/CoordinateSystem/.libs/libMgCoordinateSy
>> stem.so: undefined reference to "CPLCleanupTLS()"
>> collect2: ld returned 1 exit status
>> I see that libxerces-c.so.25 is part of the FDO setup, so is there a
>> conflict between these two versions or is it a completely different
>> problem?
Jo,
I suspect that you are picking up a different version of libgdal.so than
the one built from Thirdparty.  Perhaps a substantially older one that
lacks the CPLCleanupTLS() function?  I'd guess it is also linked against
the distinct version of Xerces.
I'd suggest digging into the link path for ld, and consider fiddling
with it to ensure there is an -L to the thirdparty copy of GDAL.
Showing the whole link command might make it easier for us to offer support.
You also might want to do "ldd libgdal.so" to find other libgdal.so's on
your system.  If you don't need them, just strip them off.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
