[mapguide-users] CPLCleanupListTLS Error (Was RE: LibXerces
conflict on Ubuntu Dapper Drake?)
Jo Cook
j.cook at OXFORDARCH.CO.UK
Fri Feb 9 10:55:23 EST 2007
Hi Traian,
Thanks for the prompt response. Unfortunately, I can't find anything to help
sort this problem out though. Has anyone managed to successfully install
MGOS on Ubuntu, or had the same problem?
Jo
Traian Stanev wrote:
> Hi, I don't think the xerces issue is causing the problem you are
> seeing. CPLCleanupListTLS sounds like a function that PROJ, the
> underlying coordinate system library for libMgCoordSys is using.
> Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of joanne cook
> Sent: Friday, February 09, 2007 9:10 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] LibXerces conflict on Ubuntu Dapper Drake?
> Hi All,
> So I've got through installing the FDO components, and the OEM
> components for MGOS 1.1.0, but the final build of the main package is
> failing with the following error:
> /usr/bin/ld: warning: libxerces-c.so.27, needed by
> /home/joc/mapguide-1.1.0/common/Foundation/.libs/libMgFoundation.so, may
> conflict with libxerces-c.so.25
> /home/joc/MapGudie-1.1.0/Common/CoordinateSystem/.libs/libMgCoordinateSy
> stem.so: undefined reference to "CPLCleanupTLS()"
> collect2: ld returned 1 exit status
> I see that libxerces-c.so.25 is part of the FDO setup, so is there a
> conflict between these two versions or is it a completely different
> problem?
> Thanks
> Jo
> Joanne Cook BSc MLitt AIFA MBCS
> Information Systems Coordinator
> Oxford Archaeology North
> This message has been scanned for viruses by BlackSpider MailControl -
> www.blackspider.com
> mapguide-users mailing list
View this message in context: http://www.nabble.com/LibXerces-conflict-on-Ubuntu-Dapper-Drake--tf3200598s16610.html#a8888237
