[mapguide-users] LibXerces conflict on Ubuntu Dapper Drake?
Traian Stanev traian.stanev at autodesk.com
Fri Feb 9 09:54:52 EST 2007
Hi, I don't think the xerces issue is causing the problem you are
seeing. CPLCleanupListTLS sounds like a function that PROJ, the
underlying coordinate system library for libMgCoordSys is using.
Traian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of joanne cook
Sent: Friday, February 09, 2007 9:10 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] LibXerces conflict on Ubuntu Dapper Drake?
Hi All,
So I've got through installing the FDO components, and the OEM
components for MGOS 1.1.0, but the final build of the main package is
failing with the following error:
/usr/bin/ld: warning: libxerces-c.so.27, needed by
/home/joc/mapguide-1.1.0/common/Foundation/.libs/libMgFoundation.so, may
conflict with libxerces-c.so.25
/home/joc/MapGudie-1.1.0/Common/CoordinateSystem/.libs/libMgCoordinateSy
stem.so: undefined reference to "CPLCleanupTLS()"
collect2: ld returned 1 exit status
I see that libxerces-c.so.25 is part of the FDO setup, so is there a
conflict between these two versions or is it a completely different
problem?
Thanks
Jo
Joanne Cook BSc MLitt AIFA MBCS
Information Systems Coordinator
Oxford Archaeology North
This message has been scanned for viruses by BlackSpider MailControl -
www.blackspider.com
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
