[mapguide-users] Building SHP on Linux
Greg Boone
greg.boone at autodesk.com
Mon Feb 12 13:44:39 EST 2007
What process did you use to build FDO and its dependant Third-party
files? Did you follow the build steps located in the FDO OpenSource
OpenSourceBuild__README.txt file?
Greg
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Gountanis
Sent: Monday, February 12, 2007 1:15 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Building SHP on Linux
configure: error: The default FDO API path is not a valid directory.
Please use the custom option
What is the simple fix for this? I have all the other FDO files built in
/usr/local/fdo.../lib seems SHP was skipped. Any idea cause I am really
burnt out on tweaking configure files :)
Chris
