[mapguide-users] ScreenToMapUnits problems
George McLean
gmclean at gorge.net
Mon Feb 12 19:44:53 EST 2007
I am guessing the problem is not factoring in the width of the layers frame.
Any thoughts or hints using ScreenToMapUnits would still be appreciated.
Thanks
George McLean
George McLean wrote:
> Hello,
> I am experimenting with the ScreenToMapUnits(x,y) function in php with
> Apache on windows XP. I am capturing the screen coordinates of a mouse
> click with javascript and attempting to convert to map coordinates
> with ScreenToMapUnits. When I compare the results of ScreenToMapUnits
> with the coordinates in the status bar, the Y coordinate looks really
> accurate while the X coordinate is off. The amount X is off depends on
> the zoom level. The farther out I am zoomed the worse it is. My
> coordinate system is Wisconsin South State Plane Grid South NAD83
> (WI83-SF). At a zoom level where the map displayed is roughly 3 miles
> wide the error is about 2000'.
> I am not sure if there is some problem in the capture of the screen
> coordinates or some other issue with the coordinate system. Has anyone
> seen this sort of problem or does anyone have any suggestions on how
> to troubleshoot this? How accurate should I expect ScreenToMapUnits to
> be?
> Thanks
> George McLean
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
