[solved] Re: [mapguide-users] Mapguide OS login failed
Chris Gountanis
cgountanis at mpower-tech.com
Fri Feb 16 09:26:02 EST 2007
When you run ./mgserver.sh you should get a very verbose startup since it is
running in /interactive or /run mode. My guess it is not starting up at all.
Did you get any errors during the compile?
Chris
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of schwanzy
Sent: Friday, February 16, 2007 2:49 AM
To: MapGuide Users Mail List
Subject: [solved] Re: [mapguide-users] Mapguide OS login failed
Bruce Dechant wrote:
The ports used by the server are specified in the serverconfig.ini file.
There is also a webconfig.ini file used by the MapGuide web extension.
The ports specified in these 2 files must match as this is what is used
for communication between the web extension and the server.
Note: These ports are independent of Apache.
Bruce
-----Original Message-----
Sent: February 12, 2007 3:54 AM
Subject: Re: [mapguide-users] Mapguide OS login failed
Jose Manuel C G wrote:
Probably the Service Mapguide Server is off line. Try to get on line.
I agree with you.
First I start apache daemon with './httpd' and I see It listening on
port 8008.
Then I start mapguide os with './mgserver.sh', but there's no output on
console, and there's no process listening on any new port.
What is the port used by 'mgserver'?
Thanks.
S.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Finally I got it working.
A provider was missing, so mgserver didn't start.
I've rebuilt fdo providers and mgserver starts listening on port 2800.
The message "username/password invalid" at mapguide administration login
made me think to different problems.
Cheers.
S.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070216/47c14d1d/attachment.html
