[mapguide-users] mgserver at 100% CPU when configuring OracleSpatial layer
Andy Morsell amorsell at spatialgis.com
Fri Feb 16 10:42:35 EST 2007
These sound like the symptoms that the first release of MapGuide Enterprise
and the Autodesk Oracle Spatial data exhibited but were fixed in MGE SP1.
It doesn't look like you have that version as I am showing mine at
1.0.0.17864.  Perhaps Topobase Web 2007 SP1 is not based on this version of
MGE?  You should probably contact Autodesk product support at this point or
post your message to the Autodesk discussion group since this list is more
intended for MapGuide Open Source.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Charly Lebrun
Sent: Friday, February 16, 2007 4:09 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] mgserver at 100% CPU when configuring
OracleSpatial layer
Dear all,
I'm currently setting a Topobase Web 2007 sp1 server (i.e. MapGuide
Entreprise 2007 v1.0.0.17804 + TB Web extension) on a Windows 2003 Srv
Standard Edition (with SP1 and latest MS patches as well). I'm using an
Oracle 10g r2 Spatial data set running on another computer.
I'm facing preformances issues with Oracle Spatial provider : when setting
up the data layer, the "mgserver.exe" process eats all the CPU during
several minutes before displaying the list of tables containing spatial
data. And once the layer is set up, all access to the map are the same :
verrrrryyyy ssslllowww with CPU up to 100%...
Anyone faced this before ? Any hints appreciated...
Thanks in advance,
Charly
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
