[mapguide-users] mgserver at 100% CPU when configuring
OracleSpatial layer
Haris Kurtagic
haris at sl-king.com
Fri Feb 16 07:54:31 EST 2007
Which provider are you using Autodesk or King.Oracle and wich version ?
In previous releases Autodesk provider was slower but with later ones should be much better.
You can also try with OpenSource King.Oracle provider.
Haris
From: mapguide-users-bounces at lists.osgeo.org on behalf of Charly Lebrun
Sent: Fri 2/16/2007 1:08 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] mgserver at 100% CPU when configuring OracleSpatial layer
Dear all,
I'm currently setting a Topobase Web 2007 sp1 server (i.e. MapGuide
Entreprise 2007 v1.0.0.17804 + TB Web extension) on a Windows 2003 Srv
Standard Edition (with SP1 and latest MS patches as well). I'm using an
Oracle 10g r2 Spatial data set running on another computer.
I'm facing preformances issues with Oracle Spatial provider : when
setting up the data layer, the "mgserver.exe" process eats all the CPU
during several minutes before displaying the list of tables containing
spatial data. And once the layer is set up, all access to the map are
the same : verrrrryyyy ssslllowww with CPU up to 100%...
Anyone faced this before ? Any hints appreciated...
Thanks in advance,
Charly
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070216/443f5ec2/attachment.bin
