[mapguide-users] .NET environment
Knight, Gregory
Gregory.Knight.bra at cityofboston.gov
Fri Feb 16 13:00:28 EST 2007
Since there seem to be some .NETers listening today, I thought Id throw
this one out there...
I use .NET/C# as my development environment. One of the reasons I chose
this environment for MGOS development in the first place was the Visual
Web Developer IDE... things like intellisense, debugging, etc...
Unfortunately I haven't been able to completely take advantage of this
environment - particularly for debugging.
First I set some breakpoints on various task pages. Then I launch my
application from the main page in debug mode from VWD. VWD launches my
application in the ASP Development Server (and after I remove the port
number that it adds), I can run my application. If I select one of the
task pages where I previous set a break point, the point never gets hit.
VWD tells me that "The breakpoint will not be hit. No symbols have been
loaded for the current document."
I assume others have got past this? If I could get past this, I might
post less questions to the list! :)
Thoughts appreciated,
Greg
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070216/37c86a10/attachment.html
