[mapguide-users] .NET environment
Brad L
bradl at mai-eng.com
Fri Feb 16 13:18:26 EST 2007
check to make sure you have debugging enabled in your config file
<compilation debug="true" strict="false" explicit="true">
I don't like the packaged webserver. If you don't want to change your ide
settings but you would like to try it in a different web server set your
start options to:
"Don't open a page. Wait for a request from an external application"
now you can open up a browser and call http://localhost/myapplication and
debug
I use the full VS product but it should be similar in Web Developer.
Brad Leighninger
Mathews & Associates, Inc.
417-869-6009
Knight, Gregory wrote:
> Since there seem to be some .NETers listening today, I thought Id throw
> this one out there...
> I use .NET/C# as my development environment. One of the reasons I chose
> this environment for MGOS development in the first place was the Visual
> Web Developer IDE... things like intellisense, debugging, etc...
> Unfortunately I haven't been able to completely take advantage of this
> environment - particularly for debugging.
> First I set some breakpoints on various task pages. Then I launch my
> application from the main page in debug mode from VWD. VWD launches my
> application in the ASP Development Server (and after I remove the port
> number that it adds), I can run my application. If I select one of the
> task pages where I previous set a break point, the point never gets hit.
> VWD tells me that "The breakpoint will not be hit. No symbols have been
> loaded for the current document."
> I assume others have got past this? If I could get past this, I might
> post less questions to the list! :)
> Thoughts appreciated,
> Greg
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/.NET-environment-tf3240988s16610.html#a9009676
