[mapguide-users] Mapguide Installation
Jack Lee jack.lee at autodesk.com
Mon Feb 19 00:33:21 EST 2007
Hi Gupteshwar,
If you see the error
Syntax error: Bad fd number
trying changing the first line of the script(Thirdparty.sh)  from
#!/bin/sh
to
#!/bin/bash
	-----Original Message-----
	From: mapguide-users-bounces at lists.osgeo.org on behalf of Gupteshwar Joshi
	Sent: Mon 2/19/2007 12:00 AM
	To: mapguide-users at lists.osgeo.org
	Cc:
	Subject: [mapguide-users] Mapguide Installation
	Hello all,
	Thanks Jack Lee for instant reply.
	Appending  bash to the command to run thirdparty script could make it run , which was giving some error at start itself.
	But still the error not been cleared I see the same kind of error after some processing.
	some bottom lines of processing .
	./Thirdparty.sh: 27: Syntax error: Bad fd number
	make[1]: Entering directory `/home/gupteshwar/OpenSource_FDO/Thirdparty'
	make[1]: *** No rule to make target `apache/xml-xalan/c/lib/libxalan-
	c.so.17.0', needed by `all-am'.  Stop.
	make[1]: Leaving directory `/home/gupteshwar/OpenSource_FDO/Thirdparty'
	make: *** [install-recursive] Error 1
	And detailed processing for reference.
	http://rafb.net/p/XztGf032.html
	Thank You
	Regards
	                 (_)
	+----oOO------------Ooo----------+
	|      Gupteshwar D Joshi            |
	              |___|___|
	              ooO Ooo
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070219/a2c3cc28/attachment.bin
