[mapguide-users] Mapguide Installation
Gupteshwar Joshi gupteshwar.joshi at gmail.com
Mon Feb 19 06:33:54 EST 2007
Hello Jack,
I made changes as per suggestion.
but still no progress.problem persist.
 it's giving me same error.
On 2/19/07, Jack Lee <jack.lee at autodesk.com> wrote:
> Hi Gupteshwar,
> If you see the error
> Syntax error: Bad fd number
> trying changing the first line of the script(Thirdparty.sh)  from
> #!/bin/sh
> to
> #!/bin/bash
>         -----Original Message-----
>         From: mapguide-users-bounces at lists.osgeo.org on behalf of
> Gupteshwar Joshi
>         Sent: Mon 2/19/2007 12:00 AM
>         To: mapguide-users at lists.osgeo.org
>         Cc:
>         Subject: [mapguide-users] Mapguide Installation
>         Hello all,
>         Thanks Jack Lee for instant reply.
>         Appending  bash to the command to run thirdparty script could make
> it run , which was giving some error at start itself.
>         But still the error not been cleared I see the same kind of error
> after some processing.
>         some bottom lines of processing .
>         ./Thirdparty.sh: 27: Syntax error: Bad fd number
>         make[1]: Entering directory
> `/home/gupteshwar/OpenSource_FDO/Thirdparty'
>         make[1]: *** No rule to make target
> `apache/xml-xalan/c/lib/libxalan-
>         c.so.17.0', needed by `all-am'.  Stop.
>         make[1]: Leaving directory
>         make: *** [install-recursive] Error 1
>         And detailed processing for reference.
>         http://rafb.net/p/XztGf032.html
>         Thank You
>         Regards
>                          (_)
>         +----oOO------------Ooo----------+
>         |      Gupteshwar D Joshi            |
>                       |___|___|
>                       ooO Ooo
> mapguide-users mailing list
                 (_)
              |___|___|
              ooO Ooo
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070219/9f498c4b/attachment.html
