[mapguide-users] Mapguide Installation
Chris Gountanis cgountanis at mpower-tech.com
Mon Feb 19 09:10:47 EST 2007
That could mean your setenvironment.sh script was not run.
Chris
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Gupteshwar
Joshi
Sent: Monday, February 19, 2007 5:34 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Mapguide Installation
Hello Jack,
I made changes as per suggestion.
but still no progress.problem persist.
 it's giving me same error.
On 2/19/07, Jack Lee < jack.lee at autodesk.com <mailto:jack.lee at autodesk.com>
> wrote:
Hi Gupteshwar,
If you see the error
Syntax error: Bad fd number
trying changing the first line of the script(Thirdparty.sh)  from
#!/bin/sh
to
#!/bin/bash
        -----Original Message-----
        From: mapguide-users-bounces at lists.osgeo.org on behalf of Gupteshwar
Joshi
        Sent: Mon 2/19/2007 12:00 AM
        To: mapguide-users at lists.osgeo.org
        Cc:
        Subject: [mapguide-users] Mapguide Installation
        Hello all,
        Thanks Jack Lee for instant reply.
        Appending  bash to the command to run thirdparty script could make
it run , which was giving some error at start itself.
        But still the error not been cleared I see the same kind of error
after some processing.
        some bottom lines of processing .
        ./Thirdparty.sh: 27: Syntax error: Bad fd number
        make[1]: Entering directory
`/home/gupteshwar/OpenSource_FDO/Thirdparty'
        make[1]: *** No rule to make target
`apache/xml-xalan/c/lib/libxalan-
        c.so.17.0', needed by `all-am'.  Stop.
        make[1]: Leaving directory
        make: *** [install-recursive] Error 1
        And detailed processing for reference.
        http://rafb.net/p/XztGf032.html
        Thank You
        Regards
                         (_)
        +----oOO------------Ooo----------+
        |      Gupteshwar D Joshi            |
                      |___|___|
                      ooO Ooo
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
                 (_)
              |___|___|
              ooO Ooo
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070219/e569f8f3/attachment-0001.html
