[mapguide-users] Mapguide Installation
Gupteshwar Joshi
gupteshwar.joshi at gmail.com
Tue Feb 20 00:21:29 EST 2007
Hello Chris
actually I tried that but it stuck at ArcSDE installation.
Which is not installed with my system (as it is optional)
Regards
On 2/19/07, Chris Gountanis <cgountanis at mpower-tech.com> wrote:
> That could mean your setenvironment.sh script was not run.
> Chris
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Gupteshwar Joshi
> *Sent:* Monday, February 19, 2007 5:34 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] Mapguide Installation
> Hello Jack,
> I made changes as per suggestion.
> but still no progress.problem persist.
> it's giving me same error.
> On 2/19/07, *Jack Lee* < jack.lee at autodesk.com> wrote:
> Hi Gupteshwar,
> If you see the error
> Syntax error: Bad fd number
> trying changing the first line of the script(Thirdparty.sh) from
> #!/bin/sh
> to
> #!/bin/bash
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org on behalf of
> Gupteshwar Joshi
> Sent: Mon 2/19/2007 12:00 AM
> To: mapguide-users at lists.osgeo.org
> Cc:
> Subject: [mapguide-users] Mapguide Installation
> Hello all,
> Thanks Jack Lee for instant reply.
> Appending bash to the command to run thirdparty script could make
> it run , which was giving some error at start itself.
> But still the error not been cleared I see the same kind of error
> after some processing.
> some bottom lines of processing .
> ./Thirdparty.sh: 27: Syntax error: Bad fd number
> make[1]: Entering directory
> `/home/gupteshwar/OpenSource_FDO/Thirdparty'
> make[1]: *** No rule to make target
> `apache/xml-xalan/c/lib/libxalan-
> c.so.17.0', needed by `all-am'. Stop.
> make[1]: Leaving directory
> make: *** [install-recursive] Error 1
> And detailed processing for reference.
> http://rafb.net/p/XztGf032.html
> Thank You
> Regards
> (_)
> +----oOO------------Ooo----------+
> | Gupteshwar D Joshi |
> |___|___|
> ooO Ooo
> mapguide-users mailing list
> (_)
> |___|___|
> ooO Ooo
(_)
|___|___|
ooO Ooo
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070220/080fef94/attachment-0001.html
