[mapguide-users] Mapguide Installation
Chris Gountanis cgountanis at mpower-tech.com
Tue Feb 20 09:38:56 EST 2007
That is OK. That should be the only warning you get if it finds all the
other paths. But setenv...sh still needs to be run before the installer so
the export vars get passed to the installer.
Chris
________________________________________
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Gupteshwar
Joshi
Sent: Monday, February 19, 2007 11:21 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Mapguide Installation
Hello Chris
actually I tried that but it stuck at ArcSDE installation.
Which is not installed with my system (as it is optional)
Regards
On 2/19/07, Chris Gountanis <cgountanis at mpower-tech.com> wrote:
That could mean your setenvironment.sh script was not run.
Chris
Joshi
Sent: Monday, February 19, 2007 5:34 AM
Hello Jack,
I made changes as per suggestion.
but still no progress.problem persist.
 it's giving me same error.
On 2/19/07, Jack Lee < jack.lee at autodesk.com> wrote:
Hi Gupteshwar,
If you see the error
Syntax error: Bad fd number
trying changing the first line of the script(Thirdparty.sh)  from
#!/bin/sh
to
#!/bin/bash
        -----Original Message-----
        From: mapguide-users-bounces at lists.osgeo.org on behalf of Gupteshwar
Joshi
        Sent: Mon 2/19/2007 12:00 AM
        To: mapguide-users at lists.osgeo.org
        Cc:
        Subject: [mapguide-users] Mapguide Installation
        Hello all,
        Thanks Jack Lee for instant reply.
        Appending  bash to the command to run thirdparty script could make
it run , which was giving some error at start itself.
        But still the error not been cleared I see the same kind of error
after some processing.
        some bottom lines of processing .
        ./Thirdparty.sh: 27: Syntax error: Bad fd number
        make[1]: Entering directory
`/home/gupteshwar/OpenSource_FDO/Thirdparty'
        make[1]: *** No rule to make target
`apache/xml-xalan/c/lib/libxalan-
        c.so.17.0', needed by `all-am'.  Stop.
        make[1]: Leaving directory
        make: *** [install-recursive] Error 1
        And detailed processing for reference.
        http://rafb.net/p/XztGf032.html
        Thank You
        Regards
                         (_)
        +----oOO------------Ooo----------+
        |      Gupteshwar D Joshi            |
                      |___|___|
                      ooO Ooo
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
                 (_)
              |___|___|
              ooO Ooo
                 (_)
              |___|___|
              ooO Ooo
