[mapguide-users] Mapguide Installation
Jack Lee
jack.lee at autodesk.com
Mon Feb 19 19:20:59 EST 2007
Hi Gupteshwar,
Did you change both build_linux.sh and Third_party.sln?
What error are you getting?
Is it
./Thirdparty.sh: 27: Syntax error: Bad fd number
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org on behalf of Gupteshwar Joshi
Sent: Mon 2/19/2007 6:33 AM
To: MapGuide Users Mail List
Cc:
Subject: Re: [mapguide-users] Mapguide Installation
Hello Jack,
I made changes as per suggestion.
but still no progress.problem persist.
it's giving me same error.
On 2/19/07, Jack Lee < jack.lee at autodesk.com <mailto:jack.lee at autodesk.com> > wrote:
Hi Gupteshwar,
If you see the error
trying changing the first line of the script(Thirdparty.sh) from
#!/bin/sh
to
#!/bin/bash
Sent: Mon 2/19/2007 12:00 AM
To: mapguide-users at lists.osgeo.org
Cc:
Subject: [mapguide-users] Mapguide Installation
Hello all,
Thanks Jack Lee for instant reply.
Appending bash to the command to run thirdparty script could make it run , which was giving some error at start itself.
But still the error not been cleared I see the same kind of error after some processing.
some bottom lines of processing .
make[1]: Entering directory `/home/gupteshwar/OpenSource_FDO/Thirdparty'
make[1]: *** No rule to make target `apache/xml-xalan/c/lib/libxalan-
c.so.17.0', needed by `all-am'. Stop.
make[1]: Leaving directory `/home/gupteshwar/OpenSource_FDO/Thirdparty'
make: *** [install-recursive] Error 1
And detailed processing for reference.
http://rafb.net/p/XztGf032.html
Thank You
Regards
(_)
+----oOO------------Ooo----------+
| Gupteshwar D Joshi |
|___|___|
ooO Ooo
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
(_)
|___|___|
ooO Ooo
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070219/c4ab07ea/attachment-0001.bin
