[mapguide-users] PostGIS selection bug?
Traian Stanev traian.stanev at autodesk.com
Mon Feb 19 14:20:25 EST 2007
It's a global environment variable, so you would do it like you normally
set those. Do it for the environment that is used to start the MapGuide
server.
Traian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Maciej
Skorczewski
Sent: Monday, February 19, 2007 1:52 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] PostGIS selection bug?
hi Traian!
> In the second example, your FID is called "gid" and so you will need
to set the PGSQL_OGR_FID variable to gid to make selection work.
ok so how can i set PGSQL_OGR_FID variable to gid?
is there any example?
maciek
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
