[mapguide-users] PostGIS selection bug?
Maciej Skorczewski maciej.skorczewski at procad.pl
Tue Feb 20 03:59:40 EST 2007
helo!
ok it's done!
when i  use shp2pgsql i get another table (whit this same shp file)
CREATE TABLE osienazwy
   gid serial NOT NULL,
   id bigint,
   idulicy bigint,
   ulica character varying(30),
   "pełna" character varying(100),
   id1 bigint,
   id2 bigint,
   kier2 boolean,
   length numeric,
   idodcinka bigint,
   the_geom geometry,
   CONSTRAINT osienazwy_pkey PRIMARY KEY (gid),
   CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
   CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
'MULTILINESTRING'::text OR the_geom IS NULL),
   CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = -1)
WITHOUT OIDS;
ALTER TABLE osienazwy OWNER TO postgres;
after that i edit it into this
change column name gid into ogc_fid.
...and it's work. now i can selected object form this postgis source.
   ogc_fid serial NOT NULL,
   id bigint,
   idulicy bigint,
   id1 bigint,
   id2 bigint,
   kier2 boolean,
   length numeric,
   idodcinka bigint,
   the_geom geometry,
WITHOUT OIDS;
