[mapguide-users] Map Image Transformation
Andy Morsell amorsell at spatialgis.com
Mon Feb 19 17:43:12 EST 2007
I think you may have to do this with two different map definitions, one with
UTM assigned and the other with LL84 assigned.  Get the current view extents
(MgMap::GetMapExtent) from your UTM map.  This will be an MgEnvelope.  Then
apply a coordinate transformation (MgCoordinateSystemTransform) to the
envelope and use that as the basis for rendering your LL84 map
(MgRenderingService::RenderMap).
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Scott Hameister
Sent: Monday, February 19, 2007 1:27 PM
To: 'MapGuide Users Mail List'
Subject: [mapguide-users] Map Image Transformation
I want to be able to Produce Map Images in Different Coordinate Systems...
..i.e. I have a mapdefinition Authored in NAD83 UTM-16 Meter...I want to
Render the current View Extents into a LL84 Image of the Map.....
....I can get the MapObjects SRS...but there is no SetSRS on the
MapObject...So How Do I change ths SRS of the MapObject, or Rendering
Service So it Renders in a different Coordinate System?
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
