[mapguide-users] RE: RE: RE: ODBC Provider with SQL Server 2005:
Doesit worksfor somebody?
pdtechguy
patroam at gmail.com
Wed Feb 21 20:57:18 EST 2007
Well I'd love to show it to those interested but unfortunately the data
points are Police & Fire vehicles…and I’ve got a house payment to make. If
someone wants the Mapguide package I’d be happy to put it on a ftp site
somewhere. The interface would probably be of little use unless you have a
Tiburon cad system.
Brad Nesom wrote:
> Very interesting. Can we hear more?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of pdtechguy
> Sent: Tuesday, February 20, 2007 11:53 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] RE: RE: ODBC Provider with SQL Server 2005:
> Doesit
> worksfor somebody?
> What I did was really pretty simple... just not for me as I know very
> little
> about javascript or html(or maps for that matter)
> 1.Created the basemap with streets and such(used our county data)
> 2.wrote an interface to our cad system that parses out the gps data and
> unit
> info and populates the sql table(s)
> 3.Created a layer of points from that data (an odbc connection to a sql
> 2k5
> server)
> I had a lot of trouble with this part and would really like to hear from
> someone who's done it right -
> 4. loaded this page as the taskpane (it's narrow enough you can's see
> anything) it's just there for the code.
> <html>
> <head>
> <title>Test App</title>
> </head>
> <script language="javascript">
> function reloadSpecificLayers(){
> parent.parent.Refresh();
> </script>
> var initTimer = setInterval(reloadSpecificLayers, 10000);
> </script>
> </body>
> </html>
> IAs a whole it work great - much much better than I thought it would. The
> ajax client seems pretty intelligent and the refresh is imperceptible
> except
> that the points move.
> Hope this helps.
> Pat
> ctallman wrote:
>> pdtechguy,
>> I would be interested in seeing what you have done and how. I'm working
>> on an application similar to this. Anything you are willing to share
>> would be very helpful.
>> Chris
>> ________________________________
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
>> DeMerchant
>> Sent: Friday, February 16, 2007 8:03 AM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] RE: ODBC Provider with SQL Server 2005:
>> Moving points, as in the locations move frequently? Do you have it set
>> up to refresh the points layer automatically?
>> Andrew
>> pdtechguy wrote:
>> It works very good for an avl map that I created as a tech demo.
>> It's is
>> displaying 30'ish moving points on a street level tiled base map
>> of our
>> county. Be happy to share any info you'd like.
>> BTW thanks to all who participate in this project.
>> Here is the sql table that contains the points I am using:
>> USE [AVL_CAD]
>> GO
>> /****** Object: Table [dbo].[avl_last_known] Script Date:
>> 02/13/2007
>> 22:26:43 ******/
>> SET ANSI_NULLS ON
>> GO
>> SET QUOTED_IDENTIFIER ON
>> GO
>> CREATE TABLE [dbo].[avl_last_known](
>> [servertimestamp] [datetime] NULL,
>> [cadunit1] [text] COLLATE SQL_Latin1_General_CP1_CI_AS
>> NULL,
>> [cadunit2] [text] COLLATE SQL_Latin1_General_CP1_CI_AS
>> NULL,
>> [caduser] [text] COLLATE SQL_Latin1_General_CP1_CI_AS
>> NULL,
>> [gpstimeofday] [text] COLLATE
>> SQL_Latin1_General_CP1_CI_AS NULL,
>> [lattitude] [float] NULL,
>> [longitude] [float] NULL,
>> [speed] [text] COLLATE SQL_Latin1_General_CP1_CI_AS
>> NULL,
>> [heading] [text] COLLATE SQL_Latin1_General_CP1_CI_AS
>> NULL,
>> [sourceofdata] [text] COLLATE
>> [ageofdata] [text] COLLATE SQL_Latin1_General_CP1_CI_AS
>> NULL
>> ) ON [PRIMARY] TEXTIMAGE_ON [PRIMARY]
>> FGoulet wrote:
>> Sure,
>> Here's the script:
>> USE [DredgingRegister]
>> GO
>> /****** Object: Table [dbo].[Dredging_Activity]
>> Script Date:
>> 01/31/2007 14:53:46 ******/
>> SET ANSI_NULLS ON
>> GO
>> GO
>> CREATE TABLE [dbo].[Dredging_Activity](
>> [Activity_ID] [int] IDENTITY(1,1) NOT NULL,
>> [UserName] [nvarchar](256) COLLATE
>> [Location_FR] [nvarchar](32) COLLATE
>> [Location_EN] [nvarchar](32) COLLATE
>> [Description_FR] [nvarchar](32) COLLATE
>> NULL,
>> [Description_EN] [nvarchar](32) COLLATE
>> NULL,
>> [Start_Date] [datetime] NULL,
>> [Finish_Date] [datetime] NULL,
>> [Dredging_Type_CD] [int] NULL,
>> [Material_Quantity] [numeric](9, 3) NULL,
>> [Material_Disposal] [nchar](10) COLLATE
>> NULL,
>> [Longitude] [float] NULL,
>> [Latitude] [float] NULL,
>> [Registration_Date] [datetime] NULL,
>> [Approved] [bit] NULL,
>> [Proponent_ID] [int] NULL,
>> [Responsible_ID] [int] NULL,
>> CONSTRAINT [PK_Dredging_Activity] PRIMARY KEY CLUSTERED
>> [Activity_ID] ASC
>> )WITH (PAD_INDEX = OFF, IGNORE_DUP_KEY = OFF) ON
>> [PRIMARY]
>> ) ON [PRIMARY]
>> GO
>> ALTER TABLE [dbo].[Dredging_Activity] WITH CHECK ADD
>> CONSTRAINT
>> [FK_Dredging_Activity_Contact] FOREIGN
>> KEY([Responsible_ID])
>> REFERENCES [dbo].[Contact] ([Contact_ID])
>> GO
>> ALTER TABLE [dbo].[Dredging_Activity] CHECK CONSTRAINT
>> GO
>> CONSTRAINT
>> [FK_Dredging_Activity_Dredging_Type] FOREIGN
>> KEY([Dredging_Type_CD])
>> REFERENCES [dbo].[Dredging_Type] ([Dredging_Type_CD])
>> GO
>> GO
>> CONSTRAINT
>> [FK_Dredging_Activity_Proponent] FOREIGN
>> KEY([Proponent_ID])
>> REFERENCES [dbo].[Proponent] ([Proponent_ID])
>> GO
>> The columns mapped to X and Y in MG Studio are Longitude
>> and Latitude. I
>> tried with others numeric type (real, decimal, numeric)
>> and I always get
>> that error.
>> Thanks
>> JasonBirch wrote:
>> Frederic wrote:
>> An exception occurred in FDO component.
>> RDBMS: Incompatible column type
>> Care to share the table definition? The problem
>> with ODBC is that it's
>> not generic enough :)
>> Jason
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Andrew DeMerchant
>> Computer Technologist
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> GEMTEC Limited <http://www.gemtec.ca>
>> 191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
> http://www.nabble.com/ODBC-Provider-with-SQL-Server-2005%3A-Does-it-works-fo
> r-somebody--tf3144880s16610.html#a9075760
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/ODBC-Provider-with-SQL-Server-2005%3A-Does-it-works-for-somebody--tf3144880s16610.html#a9093035
