[mapguide-users] transparency and gdal again
Thu Feb 22 10:54:55 EST 2007
Traian Stanev wrote:
> For bitonal rasters, MapGuide takes the foreground and background colors
> as set by Studio directly without modification. So if the background
> color is set to transparent, it should really look transparent in the
> viewer.
> However, if the provider is not returning a 1-bpp raster and instead is
> using some other color format, then the colors set in Studio will not be
> used since the code will assume that the raster is not bitonal.
Traian,
Note that GDAL promotes 1bit TIFF rasters to being 8bit paletted images with
0 and 1 set to black and white (or err, white and black?).  So if there
is special logic for 1bit foreground/background color it won't have any effect
when using the gdal provider.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
