[mapguide-users] MapGuide Viewer asks for Password on Right Click
Chris Gountanis
cgountanis at mpower-tech.com
Mon Feb 26 14:52:58 EST 2007
Yes, only happens with IE7 and MGEnt SP1 for me. The funny thing is you can
hit cancel and everything works and you don't get the box on any right
clicks after that. Every other right click after that is fine even after
canceling or typing in bad info. Also, keep in mind right click in the
layers area is fine its just on the Title area. I will keep digging and if I
find it was just me or a solution I will send feedback.
Maybe it has to do with the XML object. Did you tweak your Sarrisa.js to fix
the MSXML IE7 warnings? I was hoping a service pack would come out so I
wouldn't have to make manual changes.
Chris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: Monday, February 26, 2007 1:22 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] MapGuide Viewer asks for Password on Right
Click
I have to admit that I never knew that the legend was hidden and could be
dragged in the Layer preview in Studio. That has been one of my gripes,
that in order to test and view layer feature properties, one had to first
embed that layer in a map. But, now that I try it, the properties pane does
not work when selecting a feature in the Layer preview which may be one of
the reasons it is hidden ;) For what it's worth, I see the authentication
issue in Studio in this case.
I tried viewing a web layout in IE 7 from MGE SP1 with both the .NET and PHP
web extensions and still not encounter this problem outside of Studio.
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Monday, February 26, 2007 10:50 AM
To: MapGuide Users Mail List
Click
We've seen this behaviour in the Layer Preview within Studio. You can drag
to expose the legend. If you attempt to enable the layers the Authentication
fires. Whatever frame code is here likely is not getting the session id
passed to it is my guess.
Dave
Sent: Monday, February 26, 2007 11:46 AM
Click
I haven't seen that even when using my own wrapper. The sample application
does not behave that way either. I'm wondering if you have some other web
server authentication issues going on.
http://data.mapguide.com/mapguide/phpviewersample/ajaxviewersample.php
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris Gountanis
Sent: Monday, February 26, 2007 10:30 AM
Click
It happens when you bring in the viewer using your own wrapper. The use does
not have to enter in the password since your app does the user auth session
id stuff but then right clicking on the left bars (Layers/Properties) brings
up a enter user password box.
Basically the development guide walks you through using the viewer in your
own frame or iframe so I am sure others have seen this. Just was hoping to
not touch code in the viewer so I can get updates when new releases are out.
Chris
Sent: Monday, February 26, 2007 11:23 AM
Click
I don't see that behavior in a web layout in either IE or Firefox ........
Andy
Sent: Monday, February 26, 2007 8:47 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MapGuide Viewer asks for Password on Right Click
Is there a way to fix the viewer so it does not ask the user for a password
when they right click the Layers ^ bar or the Properties ^ bar within the
left frame area?
Chris
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
