[mapguide-users] Alternate Web Extension Location
Knight, Gregory
Gregory.Knight.bra at cityofboston.gov
Mon Feb 26 17:24:08 EST 2007
OK, that makes some sense. So I should be able to change the
"C:\Program Files" to "D:\Inetpub" then, right?
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Monday, February 26, 2007 5:17 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Alternate Web Extension Location
The viewer application requires the "viewerfiles", "localized" and
"stdicons"
directories to be on the same level as the mapviewerxxx directory.
I don't think the "mapguide" virtual directory can be changed as one of
the
viewer templates expects the mapagent to be in the same virtual path.
Regards,
- Jackie
Knight, Gregory wrote:
> I am installing the .Net Web Extensions on a new machine... and I
think
> I would prefer to put the Web Extensions folder somewhere other than
> C:\Program Files. My Inetpub directory is D:\Inetpub\www - so that
> seems like a good location to me.
> Im wondering if others have done similar and if there are any
'gotchas'
> to be aware of.
> Specifially I would like to point:
> Web Extensons - Php
> From
> C:\Program Files (x86)\MapGuideOpenSource\WebServerExtensions\Php\
> To
> D:\Inetpub\www\MGOS\Php\
> Web Extensions - .Net
> From
> C:\Program Files
> (x86)\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\bin\
> To
> D:\Inetpub\www\MGOS\mapviewernet\bin\
> ..NET API
> From
> C:\Program Files
> To
> WebStudio
> From
> C:\Program Files
> (x86)\MapGuideOpenSource\WebServerExtensions\www\webstudio\
> To
> D:\Inetpub\www\MGOS\webstudio\
> Does this make sense and will it work?
> Thanks,
> Greg
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
> mapguide-users mailing list
View this message in context:
http://www.nabble.com/Alternate-Web-Extension-Location-tf3296486s16610.h
tml#a9170514
