[mapguide-users] RE: Alternate Web Extension Location
Jackie Ng jackie.ng at aecsystems.com.au
Mon Feb 26 18:13:34 EST 2007
In theory, yes :)
- Jackie
Knight, Gregory wrote:
> OK, that makes some sense.  So I should be able to change the
> "C:\Program Files" to "D:\Inetpub" then, right?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Monday, February 26, 2007 5:17 PM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] Alternate Web Extension Location
> The viewer application requires the "viewerfiles", "localized" and
> "stdicons"
> directories to be on the same level as the mapviewerxxx directory.
> I don't think the "mapguide" virtual directory can be changed as one of
> the
> viewer templates expects the mapagent to be in the same virtual path.
> Regards,
> - Jackie
>> I am installing the .Net Web Extensions on a new machine... and I
> think
>> I would prefer to put the Web Extensions folder somewhere other than
>> C:\Program Files.  My Inetpub directory is D:\Inetpub\www - so that
>> seems like a good location to me.
>> Im wondering if others have done similar and if there are any
> 'gotchas'
>> to be aware of.
>> Specifially I would like to point:
>> Web Extensons - Php
>> From
>> C:\Program Files (x86)\MapGuideOpenSource\WebServerExtensions\Php\
>> To
>> D:\Inetpub\www\MGOS\Php\
>> Web Extensions - .Net
>> From
>> C:\Program Files
>> (x86)\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\bin\
>> To
>> D:\Inetpub\www\MGOS\mapviewernet\bin\
>> ..NET API
>> From
>> C:\Program Files
>> To
>> WebStudio
>> From
>> C:\Program Files
>> (x86)\MapGuideOpenSource\WebServerExtensions\www\webstudio\
>> To
>> D:\Inetpub\www\MGOS\webstudio\
>> Does this make sense and will it work?
>> Thanks,
>> Greg
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended
>> solely for the addressee. If you received this in error, please
>> contact the sender and delete the material from any computer.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Alternate-Web-Extension-Location-tf3296486s16610.h
> tml#a9170514
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/Alternate-Web-Extension-Location-tf3296486s16610.html#a9171518
