[mapguide-users] MGOS 1.1.0 installation problem
Dave Wilson
dave.wilson at autodesk.com
Tue Feb 27 10:09:11 EST 2007
Have you installed PHP 5.05 and confirmed it is working?
Regards,
Dave
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Farah
Sent: Monday, February 26, 2007 11:54 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] MGOS 1.1.0 installation problem
Hi friends,
I have been uninstalling and installing MGOS1.1.0 (Apache + java
configuration) several times for the last couple of days. However, I ran
into many problems: the site admin did not work and the map would not
show up and none of the map actions/tools in Studio would work.
However, this morning, I tried again and this time it worked!! :-) I
repeated the same steps as before, so im not sure what actually made it
work! :-) However, my mapguide install directory: MapGuideOpenSource had
been shared on the network . I did not take off the sharing mode while
uninstalling and installing , previously. However, the last time I
tried, I did take off the sharing on the folder, before uninstalling and
installing! :-) Im not sure if this made any difference.
The applications are working fine. The map turns up. The map tools and
commands are working in the application and studio.However, my site
administrator is still not working! When I try to login, I get an
internal server error.
When I checked the error.log in the Apache logs folder, I found these
errors:
[Tue Feb 27 12:19:51 2007] [error] [client 127.0.0.1] FastCGI: comm with
server "C:/Program
Files/MapGuideOpenSource/WebServerExtensions/Php/php-cgi.exe" aborted:
idle timeout (120 sec), referer:
http://localhost/mapguide/mapadmin/login.php
incomplete headers (0 bytes) received from server "C:/Program
Files/MapGuideOpenSource/WebServerExtensions/Php/php-cgi.exe", referer:
Does anyone know how to solve this? Please do help.
Regards
Farah
Regards
Farah
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Simon
Pelicon
Sent: Monday, February 26, 2007 2:33 PM
To: MapGuide Users Mail List
Hi Farah,
Do you have any error logs in you apache ( error.log ) and tomcat sever
log files?
This is from my conf file:
ScriptAlias /mapguide/mapagent/mapagent.fcgi "C:/Program
Files/MapGuideOpenSource/WebServerExtensions/www/mapagent/MapAgent.exe"
AliasMatch ^/mapguide/mapviewerajax/([^\?])(.*)$ "C:/Program
Files/MapGuideOpenSource/WebServerExtensions/www/mapviewerjava/$1$2"
Alias /mapguide/mapviewerajax "C:/Program
Files/MapGuideOpenSource/WebServerExtensions/www/mapviewerjava/ajaxviewe
r.jsp"
AliasMatch ^/mapguide/mapviewerdwf/([^\?])(.*)$ "C:/Program
Alias /mapguide/mapviewerdwf "C:/Program
Files/MapGuideOpenSource/WebServerExtensions/www/mapviewerjava/dwfviewer
.jsp"
Alias /mapguide "C:/Program
Files/MapGuideOpenSource/WebServerExtensions/www/"
<Directory "C:/Program
Files/MapGuideOpenSource/WebServerExtensions/www/">
AllowOverride All
Options All
Order allow,deny
Allow from all
AddHandler cgi-script .exe
RewriteEngine on
RewriteRule .* - [E=REMOTE_USER:%{HTTP:Authorization},L]
</Directory>
Files/MapGuideOpenSource/WebServerExtensions/Tomcat/webapps">
AllowOverride All
Options All
Order allow,deny
Allow from all
RewriteEngine on
</Directory>
_____
Sent: Monday, February 26, 2007 7:56 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MGOS 1.1.0 installation problem
I am attaching my httpd.conf file configuration as well...
_____
Sent: Monday, February 26, 2007 10:56 AM
Hi Andy,
My Apache http.conf file has these 2 lines:
# MapViewer to MapViewerJava Redirect. Uncomment Redirect for Java API.
Redirect /mapguide/mapviewerajax/
http://localhost/mapguide/mapviewerjava/ajaxviewer.jsp
Redirect /mapguide/mapviewerdwf/
http://localhost/mapguide/mapviewerjava/dwfviewer.jsp
I got the tomcat welcome pages when I entered enter
http://localhost:8080.
Another thing I noticed is that: After installing the server and
extensions, I go to the site administrator login page. When I try to
login by entering the username ( Administrator) and password ( admin), I
get an internal server error. ( Printscreen attached). If I replace the
mapadmin folder in the www folder, with the old mapadmin(from 1.0.2
installation), then it works fine.
However, my map does not show up in my application.None of the tools
like : zoom , pan etc seem to work in the Studio as well. The preview
does not show up. Is this some problem with the code in mapviewerjava
and viewerfiles? Please help,
Regards
Farah
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: Friday, February 23, 2007 9:52 PM
In your Apache http.conf file, do you have these two lines (or similar)?
http://localhost:8008/mapguide/mapviewerjava/ajaxviewer.jsp
http://localhost:8008/mapguide/mapviewerjava/dwfviewer.jsp
Do you get the Tomcat Welcome pages returned when you enter
http://localhost:8080?
Andy
_____
Sent: Friday, February 23, 2007 2:54 AM
Hi Simon,
I am using the apache port to run my applications . None of the
applications show the map. The studio does not show preview for any of
the layers , maps or layouts.
When I right click on the map area of the preview pane of Mapguide
Studio, it shows some error ( I have attached a screen shot.).
When I debug my applications in mozilla firefox, it shows some errors
regarding mapframe.jsp ( screen shot attached)
Regards
Farah
_____
Pelicon
Sent: Friday, February 23, 2007 4:20 PM
I presume that you are using Apache Tomcat.
You have to acces the layout page throug Apache port (default: 8008) and
not Tomcat port ( default 8081 ).
Simon Pelicon
Sl-King
www.sl-king.com
_____
Sent: Friday, February 23, 2007 11:01 AM
Hi ,
I am currently trying to upgrade to version 1.1.0 from version 1.0.2. I
am using Apache + Java configuration for developing my applications. I
uninstalled the existing mapguide web server extensions and the server.
After rebooting, I installed the new version. When I try to run my web
applications, the layout with the first page comes up. However, the map
does not show. The same is the case of MapGuide Studio 2007. The preview
pane does not show the layers or map.
I tried loading the packages again by using the site administrator.
However, that does not help. Does anyone have any pointers as to how to
solve this problem?
Thanks and Regards
Farah
Disclaimer by Mail Administrator - Yukthi
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070227/7e08d7af/attachment-0001.html
